How to create an IP address into your Printer
1, Connect to LAN network
2, Power ON the Printer.
3, Select MENU Button
4, Go to System Settings, then select Network Settings.
5, You can see TCP/IP , View IP ,etc.....
6, Type Your Printer IP address, Subnet Mask, GateWay, etc...
7, That's All......
In different Printer settings will be different.
Now You can add printer into your computer
Go to Control Panel--> Hardware and Sound -->Device and printers -->Add Printer-->Add network Printer-->"If no printer were found" Select "The printer that i want isn't listed" --> Add printer using TCP/IP--> Type your Printer IP address--> Now you can install printer software...
Thanks
