Few days back I downgraded my iPod touch 4G from iOS 6 to 5.1.1 after using my saved SHSH Blobs , I jailbroken the iDevice then installed some tweaks , the next morning I Tethered-Boot the iPod and then it went in a loop of DFU mode then the screen went completely black , I restored again , and the iPod made that charging tune and it's functioning well as well as appearing on itunes but STILL THE SCREEN IS BLACK ! i tried many times to restore (to custom/older IPSW's), hard reset, exiting from DFU, but it goes there again... I thing, i tried everything i know, also recovery mode and restore didn't work , tried to press home+power button forr 20 seconds .. nothing working PLEASE HELP !
SOURCE: Restore loop
I supose you have tryed everything they suggest on this page.
http://www.apple.com/support/ipod/five_rs/
then id suggest contact your dealer or apple for more support.
SOURCE: My iPod froze, and says it is recovery mode.
I have the same issue..I tried resetting the ipon as you suggested but still the same error everytime it starts up stating that a restore is needed...
SOURCE: ipod touch v2 stuck at itunes connect
your ipod was jailbroken and now it is not.
no worries, go to quickpwn.com
Download the quickpwn software and jailbreak your ipod.
It's pretty easy,
but first what I would do, is download the itouch firmware version you want to restore to.
the file name will be something like this: iPod1,1_2.0_5A347_Restore.ipsw
Put your ipod in DFU mode:
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Plug the
usb cable into the Ipod and NOT into the computer.
Hold the
Home Button down for 5 second (do not release it)
Then
Press and hold the Power Button for approx 10 secs (count them out)
Your iPod
will reboot.
Release
the power button and continue holding the Home button for an additional 27secs.
You may
see the screen go blank or not.
Plug the
USB end into the computer with itunes open.
Your ipod
will mount in recovery mode.
Restore
it by pressing Restore and Shift at the same time. This will allow you to select the ipod firmware you downloaded.
Restore it and then do your jailbreak.
It will ask for the same firmware version you just restored to.
find it on your computer and do the J/B
I have the firmware on my computer, shoot me an email and i will send it,just let me know if you have a 1st Gen or 2nd Gen
If this post helps you please leave a vote in fixya
SOURCE: itouch screen is white then, when restored goes black.
make sure u hold down home and sleep buttom for more than 11 seconds. After the allple logo shows up, press the home button...i had similiar problems as some of u, and this unfroze/ fixed my issue. Hopefully, it will work for u
SOURCE: Ipod wont turn on. ive tried everything! none worked! HELP!
You will want to attempt to force the iPod into disc mode before restoring. This should solve your issue.
Toggle the Hold switch on and off.
(Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Please let me know if this did not resolve your issue. :)
