I'd love to do this fix myself as sears will charge me an arm an a leg. It seems as if there might have been a spring that hold that into place as it just flops loosely now and the compactor won't close. I'd love to know a fix and details how to do it thanks
This is a job that you can do, but take your time. First there is a pedal repair kit that you will need. I have attached a link that will help you with that.
As the compactor is heavy be careful not to damage the floor when you remove it and of course make sure it is unplugged before starting for safety. I recommend sitting it on a packing blanket or rug. Then remove the kick/toe panel and follow the directions in the repair kit. Plug in and test before reinstalling.
http://www.directparts.com/
SOURCE: GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
SOURCE: Same problem
Spring is probably to the door or to the frame. This is usually what gives the tension for the door to snap back in place. There will be a series of holes on the bottom of the frame where the spring locks in. Remove the kick plate and shine with a flashlight to see where the other side is and put it in the same hole.
SOURCE: our 1 1/2 year old trash compactor will not operate
You may have to get a voltmeter or multi-tester and test voltage from power supply. Check to see if fuse is good. Check wires to pedal and lastly, use capacitor tester and test all capacitors to see if there is a faulty one.
SOURCE: Trash Compactor Model GCG1500LOBB. the foot
I also found that after 2 years my GE Profile Trash Compactor (purchased in June '07), the pedal was hanging down on the left side. I searched the internet and called GE to no avail.
After a few attempts, I finally solved the problem by removing the screw on the left side and adding a metal "L" bracket, with the bottom of the L flush against the back of the front panel. That way, when you depress the pedal, the screw can't pop out of the metal it's attached to.
Dannys00
SOURCE: I believe i overloaded my kenmore 80 series super
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
