Question about Tilia Kitchen Appliances - Others
Foodsaver v485 no longer seals
I have used it for a long time but it no longer seals like it use to
  • 7,482 Answers
Hi tami prevost
Your vacuum pump seals are wearing and not allowing the vacuum build up as it was new...
Look at the manual that came with it and see it you can order parts for your vacuum foodsaver, if you can order the seals/orings,etc that is needed to repair the vacuum part of the machine.
Please take time to rate me
Bud
Posted on Oct 12, 2012
4 Suggested Answers
6ya staff
SOURCE:
Lee Eismann
  • 88 Answers
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
Anonymous
  • 11 Answers
SOURCE: Tillia Foodsaver VAC 370 won't stop vaccuming to seal
My Foodsaver 820 wouldn't stop vacuuming, and after fiddling with it and doing a little research, I located the vacuum switch on the circuit board and de-soldered it (verry simple, only 2 solder points). On the underside of the switch it looks kind of like an allen head screw. NOTE before attempting this, make note of how far the screw is recessed into the housing and/or count how may turns it takes to remove it! I removed the screw and spring and sprayed electrical contact cleaner in the holes and in the hole where there is a little brass disc. (Wear safety goggles for this) The little brass disc is what makes the contacts that turn the pump off after reaching the necessary vacuum. Mine was gummed up and stuck so it would never make contact to shut off. I reassembled it, and re-soldered it back on the board. I then put the whole thing back together and it works like new.
You could probably make the same repair without removing the piece from the board since there is a hole in the circuit board where you can gain access to the screw, but it will be messy. If you have any experience with soldering, it is about as simple as it gets
Posted on Jun 25, 2009
Anonymous
  • 139 Answers
SOURCE: Need to get the bottom seal/gasket, foodsaver no
try using a small bead of high quality,high tempature silicon caulk. put bead over existing seal and make sure it cures thoroughly before closing or you will never be able to open it
Posted on Jul 23, 2009
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
Sep 11, 2014 | FoodSaver V3840 Vacuum Packaging System
Foodsaver v2840 will not shut off automatically
This is typically a bad seal and the vacuum cant build enough pressure. You can usually dampen the black rubber seal with a sponge and water before you use the machine. this solves the problem most of the time.
Apr 07, 2011 | Tilia FoodSaver V2240
My Food Saver V3835 will not seal canisters. It seals bags AOK but there appears to be no vacuum generated through the extension tube. We have tried several different canisters and covers. I have also...
The negative pressure is very slight and almost not detectable when using canisters for food storage. Once the system is activated, and allowed to run until timed out, the canister should have pulled all the oxygen from the canister. Foodsaver only canisters are designed for the V3835 for vacuum sealing.
How to Vacuum Package Using Your FoodSaver® Vacuum
Packaging Canister
NOTE: FoodSaver® Vacuum Packaging Canisters can only be used with
a FoodSaver® appliance that has an Accessory Port. Please check your
QuickStart Guide to see if your appliance has one.
1. Place your FoodSaver® appliance on a fl at, dry surface and plug the power
cord into a standard electrical outlet.
2. Place the item(s) to be vacuum packaged inside the canister. Leave at least
one inch (1”) between the contents and the rim of the canister.
3. Wipe rim to ensure it is clean and dry.
4. Place the lid on top of the canister. If the canister has latches, put them
in an upright position so that the lid fi ts on the base. Push the latches
downward until they snap into place.
5. Insert one end of the Accessory Hose into the Accessory Port on your
FoodSaver® appliance.
6. Insert the other end of the Accessory Hose into the hole on the top of the
canister lid. Twist the gray tip of hose while inserting to ensure a tight fi t.
7. Follow the steps for vacuum packaging as outlined in your QuickStart
Guide.
8. Remove the Accessory Hose from the Accessory Port on the appliance
before vacuum packaging in FoodSaver® Bags.
Allow hot foods to cool to room temperature before vacuum packaging. Otherwise, the
contents may bubble up out of the canister.
How to Open the FoodSaver® Vacuum Packaging Canister
To open, press and hold down the gray rubber button in the center of the lid
until you no longer hear air escaping. This will release the vacuum and allow you
to easily remove the lid.
Sep 04, 2010 | Microwave Ovens
I need a owner's manual foodsaver compact fc-no-202412 i dont no how lang to l hold it down to seal the bag.model foodsaver compact .f.l.a.e.m.nuova.s.r.l
Well you many please follow the below link to get your manual -
http://www.foodsaver.com/manuals/FoodSaver/T000-32030_English.pdf
Check out page number 4 on this manual to know the time to seal the bag.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Tilia FoodSaver V2240
I have an older model Foodsaver. The machine will
This is likely happening because the unit cannot detect that a vacuum has formed, and the gaskets around the vacuum channel are the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Dolphin Dive Center
Jul 24, 2010 | Tilia FoodSaver V2240
Foodsaver will not seal and light will not turn on or off
Dolphin Dive Center
Jul 21, 2010 | Tilia Foodsaver V835 Vacuum Sealer
Dolphin Dive Center
May 17, 2010 | Tilia FoodSaver V2240
My foodsaver Vac 420 Vacuum Sealer won't heat and seal the bags.
This is likely happening because the unit cannot detect that a vacuum has formed, and because of this, the unit will not seal the bags, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Dolphin Dive Center
Mar 29, 2010 | Tilia FoodSaver VAC420
I have a foodsaver tilia,,and don't know how to use it...I can make it seal but don't get it to pull a vacumn..
Dolphin Dive Center
Nov 05, 2009 | Tilia FoodSaver V2240
Need to get the bottom seal/gasket, foodsaver no longer has parts for this model. Do you know where I can get one?
Jul 21, 2009 | Tilia FoodSaver VAC420
Kitchen Appliances - Others Logo
991 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Sheldon Dedek
Vitally Alcher
Bonard Allen
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
