Disney High School Musical DVD Player Logo
andrea simpson Posted on Dec 30, 2008
High school musical dvd player parental control password
My daughter has a high school musical dvd player and there is a parental control on it. i do not know the password to turn this off and i do not have the manual for this device?
  • andrea simpson Dec 30, 2008
    press forward, back, forward, back (using skip buttons) then press enter
  • uirrigatio Jan 23, 2009
    YES I HAVE THE SAME PROBLEM ON THE HIGH SCHOOL MUSCIAL DVD AND I DO NOT KNOW THE PASSWORD FOR PARENT CONTROL AND DO NOT HAVE MANUEL
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2132
Points
23
Ok I have got the manual and for parental options it says
The parental option anebles parents to prevent their children from watching inappropriate material on a dvd. It reads the ratings for programming, then denies access to programmnig if the program's rating meets the limitations you selected. In this case, the user will have to enter a 4 digits security password, then press enter button.
The password in my book is forward button,backward button, forward button, backward button.
tahts the ones with the 2 arrows on.
I hope this helps i need the help line no because my little girls remote does not work with her player.
Anonymous
Level 1:
  • Posted on Feb 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2132
Points
9
Thank you, it works!!!
Anonymous
Level 1:
New Friend:
  • Posted on Feb 24, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2132
Points
Glad I found this...I have had the DVD player and tv for 4 years now, we just didn't watch the movies that didn't play...now we can
How do I reset the parental control password on a govideo dvd player?
Parental Control
Blocks playback of rated DVDs based on
their content. Not all discs are rated.
1. In DVD Stop mode, press SETUP.
2. Select Others > Parental.
3. Select the desired Parental Control
rating from "1 Kids" to "8 Adult", then
press ENTER.
4. Enter your password using the 0-9
keys, then press ENTER.
• The factory default password is
3308. If you forget your password,
this will always work.
Password
Changes the Parental Control password.
2. Select Others > Password.
3. Enter your old password using the 0-9
keys.
4. Enter your new password.
5. Re-enter your new password and
press ENTER.
My kids have lost the remote control to there disney high school musical dvd player can i get a replacement from somewhere ???
Try getting a universal remote and find the make of that dvd player and find it with the numbers that come with the universal remote. Good luck.
2answers
My daughter is wanting to watch grinch but keeps coming up tvg and wont let her play the film the registraion key is 65-265-100-10-2816-7 how do i take this off
Try taking off the parental control. Get the original password from your book and try that. If that don't work then i guess i don't know. (:
Disney High School Musical DVD Player need some code?
Hi! Does anybody knows the parental control code for the disney's high school musical dvd player? Please let me know. Thank U all!!!
Deleteing music
Put songs your daughter does want on the MixMax, and then click "shuffle". It should load the new songs while deleting the old ones. Good luck!
1helpful
2answers
Parental control on disney princess television
the master password is 5963.....after you enter that it will ask you to create a new password.
2answers
Dvd troubles
Same problems with my unit.  But, try this... I think it worked.  First, you can not get to the setup screen for the unit with a DVD in the player.  So, remove the DVD first:  Unplug the unit, wait a few seconds, plug it back in.  Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play.  At the Sony Blue DVD screen, select Setup on the remote control.  Select DVD setup and get to Parental control.  Set a password.  This will then take you to a "rating" screen.  By setting the rating very high (I set mine for #8) any movie should play without needing the password.  With no password set, you can not change the "rating" and hence mine was set at #1 (kids).  It seems to have worked for now anyway.  Good luck.
Panasonic recoring onto DVd won't playback on other DVD's
You need to "Finalize" it. Refer to the manual for the procedure (it's not hard at all).
Top Disney Audio Players & Recorders Experts
Alexander
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
