2700 EC1 Series
SOURCE: do you know if it is possible to get a walking
No I haven't solved it, nor am I prepared to pay for it
SOURCE: I need a manual for a toyota sewing machine
http://isi.m6boutique.com/m6b/manuels/MCYF_MU.pdf
Check the above link. I need the exactly the same manual and I found it there. Good luck
SOURCE: how to adjust tension on Toyota RS 2000 sewing machine (CB series
Hi
I found a free manual and parts for my Toyota 9090 on this site. http://www.aisin.fr/index3.php?language=en
The only problem is that the manual is in French but some are also available in English. I found it useful for the diagrams etc.
Try the online guides as well as they give help on adjusting tension, replacing bobbins and needles etc.
SOURCE: I have a Toyota 2700
Can you get inside to get at the lever? Spray the reverse mechanism with sewing machine oil or WD40. Be sure to clean the mechanism first.
If the feed direction is forward after you oil it, great! If not, it's off to the repair shop.
I hope this works for you. Thanks for visiting fixya.com
Handie Andie
I'd appreciate your vote. Thanks.
