Motorola Mobility MOTOROKR T505 Logo
Anonymous Posted on Sep 06, 2017
T505 was clear broadcast before - now there is excessive static on every station
This just started happening about 4-5 months ago... the unit is about 4 yrs old and worked flawlessly before. it's paired with a Nexus S. The Nexus has no distortion when playing without T505. The car speakers are distortion-free when playing radio or CD. Have used the T505 undercharged, fully charged, continually plugged in, and unplugged ... makes NO difference.
4 Related Answers
Anonymous
  • 394 Answers
  • Posted on Aug 14, 2010
SOURCE: I have a new T505. However, I am having trouble
upgrade its software
Anonymous
  • 1566 Answers
  • Posted on Nov 05, 2010
SOURCE: I am trying to pair my t505 with my HP Mini
Hello there,
Have you tried clearing all previously paired bluetooth devices and then starting anew?
Let me know about the steps you are doing in order for me also to replicate it from my end.
Looking forward to your response.
Anonymous
  • 43 Answers
  • Posted on Feb 09, 2011
SOURCE: my t505 is connecting while
delete pairing from and reconnect it back
casouzaj
CARLOS R SOUZA JR
  • 1118 Answers
  • Posted on Mar 27, 2011
SOURCE: I pretty sure I'm going
Well, I have this marvellous car kit for a couple of years. It worked just fine with my old Acer Tempo M900 (WM6.1) phone, and, presently, is serving me just perfectly, paired with my Motorola Defy (Android Eclair). But, bear in mind that these phones of mine have bluetooth radios buit-in. On the other hand, as far as I know, the LG VX6000 of yours seems to lack this feature. It's not clear to me, after reading its interactive user guide, whether it has an audio socket (e.g. a standard 3.5mm or a less common 2.5mm one, in diameter) or not. In case it does, you would need to search the market for an audio adapter which bears, at least, the A2DP (Advanced Audio Distribution Profile) bluetooth profile, and, besides, whose pairing code is '0000 (four zeros), which you would connect to your phone's audio socket. Otherwise, i.e. if it lacks an audio socket, ,I'm afraid you would have to switch to another phone, in case you want to use the T505 that bad. If so, choose a phone with buit-in bluetooth functionality. You must have already read on many reviews of this car kit, that it picks up music from your phone through stereo bluetooth (A2DP), and broadcasts it through an empty FM frequency, to be tuned in by your car's antenna.
Please, let me know if you need further informations about it.
Regards, Carlos
1helpful
Limited radio stations
Check the connection from the radio to the antenna.May not be plugged in.
1helpful
My Denon Stereo Receiver (DRA-345R) (quite an old model but has worked perfectly up until now) has a very static reception on AM. FM is fine. It started when I had my DirecTV upgraded with a Genie (whole...
it's obviously getting interferance fronm that whole house broadcast unit (not abnormal!) best and only thing you can do is to move the stereo to a place where you can get the MOST am stations the loop ant. is exactly what it says it is a loop of wire with two ends..both ends connect to the ant. input on the back of the unit..however if that whole house broadcast unit is the devil then an ant. no matter what or how it's made will only recieve more static not built to reject static! so you've got to move it unfortunately ..fm is a totally different band obviously fm isn't being affected by that whole home broadcast unit..you're lucky! on that count
1helpful
I can't see the the wifi network
Wireless routers can broadcast on several different channels, similar to the way radio stations use different channels. In the United States and Canada, these channels are 1, 6, and 11. Just like you'll sometimes hear interference on one radio station while another is perfectly clear, sometimes one wireless channel is clearer than others. Try changing your wireless router's channel through your router's configuration page to see if your signal strength improves. You don't need to change your computer's configuration, because it'll automatically detect the new channel.
1helpful
Bad Radio reception in new 2009 Mazda3 Sport GS model
I would venture a guess that the antenna wire that plugs into the back of the radio is not seated properly. Did the dealer tech just listen to the radio or did he/she actually check the connections on the back of the unit? A faulty antenna connection would explain why it only happens with some stations and not others. Maybe the stations that are not being a problem are transmitting a more powerful signal or are closer in range than the ones that you are having trouble picking up clearly. Just a thought. Hope this helped and best wishes.
2006 Lincoln Zephyr - Static on radio with rear window defroster
check for antenna ground if corroded relocalize the ground.
1helpful
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
2answers
Radio effected by brakes?
If this happens when the car is still you have voltage interference between brake light voltage & antenna. If this happens from motion check all wire connections, loose antenna wire, to antenna.
Bad reception
I see you've already read the "Troubleshooting" section of the manual! The only other things I can think of to check would be the actual connection between the radio (aka head unit) and the antenna. It's usually just a press-fit connection behind the radio, but if it's loose, corroded, or is touching some other metal, it could affect the reception.
There's also the small possibility something changed at the transmitter tower for the radio station. That happened in my area once, where they changed the direction in which most of the signal power was being broadcast. Westside reception got better, eastside reception got worse.
3answers
No video just sound
this should read"The sound comes in perfectly clear, just NO video."
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
