Error on screen says printead carriage jam, there is no jam normally when you open printer to see in come to the middle but it doesn't. press ok or cancel to clear screen but nothing happens error screen comes back on. Called kodak and said that software/hardware has gone can i solve this or should i get a new one?
SOURCE: Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
SOURCE: Kodak ESP 3250. Error 3527. I put new ink
Contact Kodak. I think it's the batch of printers that were made around this time. I just contacted them (mine is the same age and I'm getting the same error), and they are sending me a new printer.
SOURCE: Paper jam, paper cleared, ink
Your error code, 3821, means that the internal memory is screwed up!
Solution:
Unplug the printer for a whole minute for the memory to discharge itself. Anyway, that will force a memory reload and everything will be just fine.
Also, here is an alternate fix if the one above (which is the fastest way) does not work:
Open and close the front door, if this does not reset the machine, turn off machine, switch back on while holding the utillity/counter key, after you see a black dot in the corner of the lcd let go of the utillity/counter key. the machine will take a while to boot up, and when it does you will see trouble reset on the lcd, press the reset on the lcd, switch off the machine leave it off for 10 to 20 sec's and then switch back on. If this does not work you have a screwed fsr, if it does work, it might come back at some point if the firmware is not up to date , the latest is vR6
