Mp3 kept turning off, so connected to device manager which said there was a fualt, clicked on repair and after about five mins said all was repaired. now screen says file system error and will not register when pluged in on usb?
how do i get player back to normal? philips consumer care not replied to give any help.
Once you have Songbird installed, launch it and select "Repair my Philips device" in the Tools menu. Select your device and follow the instructions specific to your device. For example, instructions for the GoGear Vibe are to disconnect the device, power it down completely, and hold the volume-up key during and after USB connection until the message window disappears.
If the repair utility endlessly indicates it is checking for updates, you are likely using an out-of-date version of Songbird - probably the one that came with your GoGear. If this describes your situation, launch Songbird and select "Check for updates" in the Help menu. This will at least get you upgraded to version 1.9 (currently), even though the latest version is 1.11 (currently).
Instructions that came with some older versions for connecting GoGear in repair mode were incomplete. They left out a crucial step of turning off the GoGear and waiting for it to power down completely before reconnecting in repair mode. Newer versions of Songbird include the ability to reformat the device, reset the device, and to get progress updates during synchronization.
If you've found this information helpful, please indicate as such.
Hi! When you repaired your mp3 player you formatted it with ntfs file system but your player needs fat32 file system. Don't be upset just plug in your mp3 player again with your PC and reformat it by changing the file system to FAT 32. Hope this helps.
Hi bysvraju...
Try this method...
************************ Go to Device Manager To get to Device Manager you will: Right click on My Computer>Properties>click the Hardware Tab>Device Manager. After you are in Device Manager look for your MP3 player or Unit. Here you should see no "Yellow" exclamation points. If you do they they are telling you that you have a device conflict. If you currnetly have your unit plugged in, you may notice the "unknown device" which would be your Player or Unit. If you unit has an exclamation point by it, then you will need to click on it and delete it. After you remove all devices with conflicts then click on refresh and search again for your MP3 player/Device. The computer should install your device this time and solve your problem with connection of the MP3 player/Device. Please take time to rate me thumbs up.
If you have a Philips HDD Series, it will not work with Windows Vista or Windows Media Player 11 except for briefly, then the player will stop working one day. Your only hope is to use it with Windows XP and Windows Media Player 10 - it is, basically, an obsolete player at this point in time.
The Philips Device Manager has a strange feature - it only properly updates your device if you have the newest version of the Device Manager: Download the newest version of the Philips Device Manager: www.usasupport.philips.com - change your country/language as needed Enter in your exact model # Click on the link for your exact model # Click on the Software & Drivers section Click on "Firmware Upgrade Software" Install the new Device Manager Open and run the "Update" tab -Tha Mp3 Doctor
Download the newest version of the Philips Device Manager: www.usasupport.philips.com - change your country/language as needed Enter in your exact model # Click on the link for your exact model # Click on the Software & Drivers section Click on "Firmware Upgrade Software" Install the new Device Manager Open and run the "Repair" tab -Tha Mp3 Doctor
Recovery Mode for Philips' GoGear Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.Then click on the “Repair” button to start the repair process.Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded. -Tha Mp3 Doctor Philips GoGear Firmware Upgrade You need to get the latest firmware upgrade from the Philips website: 1. Go to www.philips.com/support 2. Enter your country/language 3. Enter your model # SA6045 or whatever 4. Click on the link for your exact model # (the one w/o the "B" in it) 5. Click on "Software & Drivers" 6. Download the updated "Device/Firmware Manager" 7. Once installed, open the Philips Device Manager 8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course) 9. Your Mp3 players firmware will update automatically If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date." -Tha Mp3 Doctor
Recovery
have to be reloaded. Philips
Mp3 Doctor
You have to do the "update" in the Philips Device Manager (make sure you are connected to the internet when you do) to repair the corruption:
Recovery
Philips
Mp3 Doctor
Make sure the lock switch is off.
Reset method is power on plus volume + at the same time for 5 to7 seconds.
Recovery
Philips
Mp3 Doctor
Make sure you back up all songs on the GoGear before attempting this solution. 1) Back up all files on the GoGear 2) Open up Philips Device Manager (Start --> All Programs --> Philips) 3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button 4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard). -Tha Mp3 Doctor
