Toner tray is jammed. Can't open to change cartridges.
Open and close front door, wait for the motors to start turning about 1 second then open front door. toner tray should now slide out.
After further research it appears it is a toner cartridge it is hanging up on. Most likely a compatible toner cartridge. I have also found that simply opening front door, pull toner tray out til it stops then push it back in til it locks, then open close and open front door. This seems to release it.
Call hp and sit on the phone until they answer. They will talk you through it.
Jam ()
Orange
On
A paper jam has occurred. (See Clearing paper jams.)
Online/Error ()
Off
The machine is off-line.
Green
On
The machine is in power saver mode.
The machine is on-line and can receive data from the computer.
Blinking
When the LED slowly bilnks, the machine is receiving data from the computer.
When the LED rapidly blinks, the machine is printing data.
Red
On
The cover is opened. Close the cover.
There is no paper in the tray. Load paper in the tray.
The machine has stopped due to a major error.
Your system has some problems. If this problem occurs, contact your service representative.
A toner cartridge has almost reached its estimated cartridge life[a]. It is recommended to replace the toner cartridge. (SeeReplacing the toner cartridge.)
Blinking
A minor error has occurred and the machine is waiting for the error to be cleared. When the problem is cleared, the machine resumes.
Small amount of toner is left in the cartridge. The estimated cartridge life[a] of toner is close. Prepare a new cartridge for replacement. You may temporarily increase the printing quality by redistributing the toner. (See Redistributing toner.)
