SOURCE: my toro 51970a trimmer has
The carburetor needs to be removed and inspected. The malfunctions possibly indicate the need for a repair kit. I've been unable to locate your exact model, but if it has the 2-Stroke engine (gas/oil mix), then you will at the very least..need a gasket and diaghragm kit installed per inspection. There is the possibility that the carburetor needs a complete rebuild and would require the complete rebuild kit. Remove the gas lines (after draining gas). Remove the carb and inspect the screws and tightness of the screws in the 2 end covers. Are the screws tight? If not tighten them up and reinstall, trying to restart the machine. Post back if needed.
