My Sony Trinitron tv will not turn on. The "standby/timer" light is blinking, but the tv power will not turn on, even if I push the power button on the front of the tv. It worked fine last night.
Tv will not turn on the timer standby button is blinking i push power button but it wont turn remote wont turn tv on eitherTv will not turn on the timer standby button is blinking i push power button but it wont turn remote wont turn tv on either
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail. "Electro-help", is the name of the site. Search for it on Google.
4 times standby light blink shows that tv got problem in vertical deflection section and probably vertical output IC got defective, need to be replaced. Replacement of parts in circuit board requires soldering work and expertise so call local tv repair shop guy if you are not familiar with soldering work. Thanks.
The standby light should be blinking in a repeated pattern. Count the blinks and report that number here. This will indicate the circuit that is defective and will allow us to provide a repair suggestion.
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Same problem. The standby light is blinking, but TV won't power on.
