How do I change the time on our NEC DT300 Series phone so that I can update for daylight saving thanks. The info on the back of the phone is - NEC DT 300 Series DTL-24D-1A(BK) TEL Model: DLV(XD)Z-Y (BK) Hope this helps.
What model of NEC phone system do you have? Go look in the phone or data room and look at the PBX. You might also be able to press Feature 3 to get some information which would be helpful to a tech. If it is an SV8100 try this: To set the system Time: 1. Press Speaker. 2. Dial 728. 3. Dial two digits for the hour (24 hour clock, 13 = 1:00 PM). 4. Dial two digits for the minutes (00~59).
5. Press
Speaker to hang up.
SOURCE: how do you change the time on a nec phones dth-8d-1(bk)tel
To Update Time: From operator telephone with receiver hung up; Press feature key; dial 9,#; enter hour and minute i.e. 0135; (press recall key to change from am to pm); press feature key to save and exit.
SOURCE: How do I change the time on NEC DT300 phone
Press the function key
press 9
look at your display and you will be able to change the time
Press function key to save
Usually done from the administrators phone
SOURCE: change the time
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
SOURCE: Set Time DTH-16D-1 (BK) TEL
Here's how you adjust the time:
1. Press <TRANSFER>
2. Press <CONF>
3. Press *
4. Press <TRANSFER>
5. Press <CONF>
6. Press #
7. "CAT MODE" displayed on LCD
8. Press <REDIAL or LNR/SPD>
9. "COMMAND" displayed on LCD
10. Press 02
11. Press <RECALL>
12. Press 2
13. Press <RECALL>
14. "02>2>Current Time" displayed on LCD
15. Input correct time using military time (HH MM SS)
16. Press <CONF>
SOURCE: Headset for NEC Dterm80
Do a search for a plantronics headset. All of theirs work well with NEC
It worked thanks for a spot on solution
do not disturb in stuck on DND all
model#- dlv(xd)z-y(bk)
How do I change the time on our NEC DT300 Series phone so that I can update for daylight saving thanks. The info on the back of the phone is - NEC DT 300 Series DTL-12D-1P(BK) TEL Model: DLV(XD)Z-Y (BK) Hope this helps.
