Washing Machines Logo
Posted on Oct 07, 2012
What is a code OE - LG WM-0532HW Front Load Washer
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 07, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
44
Points
Oe code is a long drain error or no drain remove the pump check if there is something in it if not replace pump
2helpful
My similar washing machine gives an OE error. It washes but won't spin giving the OE error. Please help
OE error code indicates that the washer is unable to drain the water it used during the wash cycle. OE can be triggered by a kinked drain hose or a clogged drain pump filter..... please clean drain hose back side of washing machine.. Thank you
1helpful
Krups EA8050 code OE. Can i reset code OE manualy.
It says Contact service center if you removed the water filter and the error is still coming up.
They refuse to give a better answer than just to let it be repaired by them.
Wont spin keeps coming up with oe on screen what does this mean
LG washing machine error code OE. Error code OE on The LG washing machines simply means the pump is blocked. Presumably the water isn't being emptied properly you might have something blocking the pump.
https://www.youtube.com/watch?v=JBCodfFo6Bc&vl=en
https://www.youtube.com/watch?v=KixjQQdGNF4
https://www.youtube.com/watch?v=A4ENzr2ZR1c
2helpful
2answers
OE error please
There may be a few different reasons why the OE error code can display on your washing machine. Is it the LG washer getting the OE error code? The OE error code on the LG washing machine display is an indication of a NO DRAIN issue. The 3 issues that may cause this fault code is a bent drain hose, the drain pump filter is blocked, or the drain pump may have foreign objects lodged in it making it unable to drain. All these issues can cause your LG washer to display the error code OE. With all these different reasons, checking all 3 components will clear the error and fix your LG washing machine.
OE error code dish washer. hose and filter okay. runs for 2 mins and stops. water over filter area?
This is the fix for the oE error code.
https://m.youtube.com/watch?v=V04PvdyWVTM
1helpful
2answers
What are the common fixes for OE Error Code?
OE error code is an Outlet Error.
That has to do with the drain itself. It can come up when the unit is draining slowly, it has nothing to do with water-level really. I would suggest makign sure that your drain hose is not crimped / crushed / or obstructed first before going onto other problems.
I have a code that sa OE and dont know what it means
Check out this tip it will help explain that OE code
LG Washing Machine OE Error Code
heatman101
My machine is showing an oe code and won't drain
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation.
1helpful
Error code OE?
OE = drain hose blocked or clogged, or the drain filter is clogged
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
