Dryer just stopped turning seems to be jammed maybe belts broken?
More than likely a broken belt. A fairly easy fix. Disconnect Dryer electric by shutting off the breaker. Then remove the front panel that surrounds the door. There are ususally a couple of screws on the bottom and you have to pot the top. Get a belt off the net or from a appliance dealer. The belt slips around the drum over the motor shaft and on a tension Idler wheel. Pop is back together and you good to go. Try checking You Tube and see if there is a video on dryer belt replacement. Good luck! :)
Testimonial: "thanks i will order a belt and change it...i appreciate your advise thank you "
SOURCE: when turning on dryer you here a humm noise like
sounds like you have a faulty motor burning smell means overheating or shorting could also be faulty wiring or control you should cal an appliance serviceman good luck let me know how you went
SOURCE: Maytag Dryer
hi thanks for the question the belt has stretched replace the belt thanksthe appliancedoc
SOURCE: the dryer is not turning where do and how do get
you will have to remove the front panel. screws are on the inside of the door, may be two on the bottom corners, with a flat tip screw drive gently pry up on the top corners. remove panel disconnect door switch, the belt goes around the drum to the motor and has rollers on the back of the drum. I even think on the backside there is a rest button. Hope this helps Tim
