1)this a problem by lack of maintenance schedule. LUBE the deck belt, probably you have a worn deck belt.
2) Lube the rollers bearings too , inmediately.
3) measure the input voltage motor in the terminal, if there are the motor need repair.
4) measure the output voltage board, if there are NOT the board is faulty.
se the block diagram. attached. see my personal TIPS
God bless you
SOURCE: Horizon Model 3.2E LCD showing MILE EP 5101
THis is a reboot error. The upper control board is not loading properly. It might flash temporarily but If it stays on the upper control board will need to be replaced.
www.twincityrepair.com
SOURCE: Erratic speed on Horizon treadmill.
Treadmills Erratic speed on Horizon treadmill. Solve Hi The speed of the treadmill does not correspond to the speed control key. Any... (More)
SOURCE: I have a T54HR horizon treadmill. The problem is
best if you see the local retailer where you bought the treadmill. Obviously the switch, whick is a magnetic disc is not activating the sensor in the control panel and need to be looked at.
SOURCE: Horizon Treadmill T5.1. A sudden vibration and
To find a specific bearing that has gone bad in a treadmill you can use a long handled screwdriver and touch it to a non-moving portion of the rollers and then put your ear up to the handle and the screwdriver will amplify the noise of the part so you can find out which part is making the noise. If it is a bearing, it will be obvious which part is the problem because the grinding noise of the bad bearing with be amplified by the screwdriver.
SOURCE: horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
