The tv turns on picture comes in and out. lamp as been replaced already
SOURCE: Samsung TV: lamp out
Yes,tries websites like Tvrepairworld.com,Partstore.com,Ebay.com to buy a projection lamp for the replacement.Tv have "LAMP"indication LED light is flashing or staying on.If the projection lamp on the tv now,been in used 4 or 5 hours a day watching the tv.The projection lamp has not been replace the last 1 1/2 or 2 years on the tv.The projection lamp life is over,require changing.The tv also making clicking noises,the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
SOURCE: Samsung DLP HL-P5063W. . .no lamp!
I have the exact same problem, TV stared doing it about 12 days ago, I ordered and replaced the Lamp, it still does the same thing...
""Lamp" light flashes for 20 seconds and then you hear PS clicking,
repeats cycle 3 times before it shuts off and all 3 lamps flash!"
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
SOURCE: samsung dlp tv no picture
Sure, you can test by Use the screwdriver and remove the protective cover that conceals the ballast.
Observe the ballast before proceeding. If oil is leaking from the ballast, stop here and remove the ballast. Leaking oil indicates that the ballast is damaged beyond any doubt as the internal seal has been ruptured by excessive heat.
Test the high voltage side for continuity between the wires going to the ballast tombstones. There will be either one or two wires going to each tombstone fixture. Regardless of the number of wires, the colors will be the following: Blue or yellow are the power wires and white is the common or neutral wire. this could differ in many models.
Turn the Volt Ohmmeter to "ohms" and touch the ends of the two probes together. The meter should show continuity or a direct short. Touch the probes of the meter to one of the white wires and one of the colored, blue or yellow, or any wires that comes from the ballast. This should show a short or continuous circuit. If it does not, the ballast is bad and should be replaced.
SOURCE: Samsung Model HLR6167W
Does the lamp light if not and you are sure you have a good lamp check the ballast and make sure you have voltage coming from it.
