My webcam is connect to the computer and the program which it runs on opens but the webcam light does not come on and there's no picture. Whenever i try to record it comes out black with no sound.
Try updating the driver. here is the link:
http://www.microsoft.com/hardware/en-us/d/lifecam-hd-6000-for-notebooks
SOURCE: Lifecam VX-6000
Uninstall the Microsoft LifeCam and disconnect your camera.
Go to this site: http://www.logitech.com/index.cfm/435/241&cl=us,en
Download the software for the QuickCam Ultra Vision 5. Save to your hard disk and then run the program.
Reinstall the LifeCam software and then plug in the camera. LifeCam will use the Logitech Drivers and your camera should work fine.
SOURCE: Microsoft webcam VX 6000. Buzz on video capture
I took the cam apart, removed the mic from its seat and gently separated the red and black wires - ran the red one over top the lens and the black one underneath. Replaced the mic, screwed it all back together and the problem is gone. For now. One tip is to record sound using Windows Sound Recorder while you're doing this, watch the input line and when it goes flat you know the buzz is gone. While it buzzez, the line will be active.
SOURCE: blue screen appears when I instal Microsoft nx-6000 cam
uninstall the Cam software.restart the system Click>start>run>type verifier>ok >u will get a window for Microsoft Driver Verifier click next twice (it will search for Unsign Drivers)if any Click next restart.Now install ur Cam Software it shouldwork.
SOURCE: no sound on webcam video call ONLY
You will probably need to reconfigure whatever software you are using for the video call to pull audio from the Onboard Mic from the Cam. If it is not configured to pull the audio from that Mic on the Cam, it may be looking for audio somewhere else. This is sadly an issue with a lot of Video Chat software applications.
