Navigon 2100 Portable GPS Receiver Logo
Anonymous Posted on Oct 06, 2012
GPS my gps powers up then error message comes on ?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Oct 06, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
1502
Points
25
Gprs is most beautiful internet concretion.
On-site training also allows a business to schedule training around workflow, eliminating the risk that professionals will leave for training during a busy period of the day or crunch time on a project. This avoids costly downtime and makes workflow as efficient as possible while still ensuring employees receive the education they need.
Gps-1 not working on my d90, it say option not available
The D-90 does not come with an internal GPS. However, one can be connected. If you have connected a GPS and are getting this error message, I would suggest you contact both Nikon at www.nikon.com and the GPS manufacturer to get help in troubleshooting the problem.
When I turn on my dale jr gps, I get a Warning Box that says "Can't find the gps program! please set gps in File Manage! PLEASE HELP. The music comes on at start up but that's as far as I can get....
There seem to be a problem somewhere, that is why the shows you the error message, 'can't find the gps program'. The problem is that a file or more is missing, and the file is what starts up the gps. This is a software problem. First try to reset the gps by removing the battery and installing it back, then you press and hold the power on/off button for about 15 seconds, then it will restart. If it does the same, then you need to get the gps out of the car or anywhere it is and connect it to the computer using the USB cable, then you format the gps and reinstall the software and maps back on it. That will do the job for you. I am 100% certain about that.
4helpful
While using my Magellian GPS 1200 the screen froze up and when I went to restart it the following messang appeard.SD card has been removed.Program will restart.Please insert SD card with map. I tried re...
More then likely when the screen froze up on you it it had a little power glitch as well, nothing serious but it did wipe out some of the information in it's memory about the SD card.Power the unit up and let it come up with the error, then use the reset button. Might be hard to find since it's just a little hole with the word reset around it, using a paperclip push in the button and see what happens. If the error comes up again then i am thinking that you will need a new SD card. Quick test for this, remove the SD card from the gps unit and try rebooting, it should come up with an error, no SD card or no map, stick in an SD card from another device, 2gb, see if the gps can find the card, it should give you an error that says unable to find maps. If you get these error codes then most likely the gps unit is fine but it pooched your programs on the SD card.
Hope this helps
1helpful
2answers
Magellan 3100 frozen on blue screen with black progress bar
where are you getting that error message, on the pc or the 3100
When the "no detailed maps found that support routing" screen comes up it covers any of the icons, so I'm unable to do anything.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
3helpful
5answers
Gps error message "gps module not responding"
Check the connectors and wiring between the GPS module and sonar unit. If it's an internal GPS module yo may have knocked loose a connector internally.
"Unable to launch application" error message
This is a software problem that requires the Magellan GPS software on your GPS device to be updated the latest version, or sending the GPS device in for repairs and updates.
I would recommend sending the GPS device in for repairs since many people have had no luck updating the software when having the Unable to launch application error.
Here is a link to the MagellanGPS Technical Support page:
http://support.magellangps.com/support/index.php?group=default&languageid=1
Iā€™m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
My error message says "A GPS-signal is not available now...."
Try hinging the antenna out from the back and angling it so the words FineDrive point up at the sky. It often takes 5 or more minutes to find the satellite, but it always finds it.
Error messsage when downloading Gps
what was the error message?
all the e's and I""were converted to" "u"'s ?
We like to help but if we dont get a full description the crystal ball does not focus properly
Top Navigon GPS Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Navigon GPS Expert? Answer questions, earn points and help others
