Question about Mitsubishi HS-U770 S-VHS VCR
Plays for 3 secs, stops, and then ejects
Mitsubishi HS-U62 S-VHS. DJ4+Twin Fe super VHS.
I put the tape in, it plays for 2-3 seconds, it stops & then ejects. Ugh!
  • mlkurland Dec 31, 2008
    Thank you so much. I'll give it a try, Dan.
  • 4,234 Answers
This unit needs to have the "idler" changed as well as the belts. Over time, the internal rubber parts get hard ans slippery. There are safety checks inside that will stop the unit when problems are detected. With a slipppery idler assembly, the tape does not get wound into the cassette after passing the heads. Rather than have the tape collect inside and be destroyed, the unit stops. This is a relatively simple repair that any shop should be able to perform. Expect a parts cost in the $35 range. In my opinion, this unit is worth the repair as it will continue to provide service to you for years to come. New replacement units tend to last only a year or two.
Dan
Posted on Dec 31, 2008
6ya staff
SOURCE:
Mitsubishi hs-u62 vcr cassette will not eject
Needz fresh belts. You can order common o-ringz uv the same length that will work fine, but usually not az long.
Apr 19, 2015 | Mitsubishi Televison & Video
I have a Mitsubishi HS-U448 VCR. It plays my VHS tapes fine, but I can't get a blue screen when I turn it on. When I press 'play', the movie looks great. Once I hit 'stop', it'
It sounds like it is set to a TV station and since all the analogue stations have now gone you will only get static. Without a remote you wan't be able to switch it. I suggest you either shop around for a replacement (try Curry's partmaster) or use a universal one.
Jan 16, 2013 | Mitsubishi HS-U448 VCR
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
VHS tape plays for a few seconds and automatically ejects
My guess would be dirt on the rollers inside the VCR. They sesnse a jam and ejct. Try a VCR cleaner (with cleaning fluid) and see if that helps.
Feb 21, 2009 | Symphonic WV806 DVD Player/VCR
Cassette player
the tape is very tight
get a pen and try to loosen up the tape
100 % is the tape not the radio
May 15, 2008 | 1999 Ford Taurus
Error E3 on Mitsubishi HS-U795
Try this :
If your VCR malfunctions, try the following steps prior to contacting your Mitsubishi Dealer:
1 Check the Trouble Checks below to see if there is a solution to the current problem that you are
experiencing.
2 If the problem is not addressed on the Trouble Checks, the safety circuits in the VCR may be in
operation, thus please try the following: (the clock setting and the timer recording will be deleted.)
1 If possible, press EJECT on the front panel and remove the tape.
2 Press TIMER RESET on the rear panel with a pencil or a ball point pen.
3 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, wait about 1 minute
until the tape protecting function is completed, then press POWER.
3 You may also try the following procedure if the above steps did not resolve the problem (All settings will
be reset to the default settings.).
1 Press POWER on the front panel continuously for about 8 seconds until the current time display on
the front panel shows "- : - -."
2 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, the tape protecting
function will work and "99" will appear on the front panel display to begin count down. Wait about 1
minute until it reaches "00" to show the tape protecting function is completed, then press POWER.
If the problem with your VCR persists, contact your Mitsubishi dealer for assistance.
Im looking for error codes.
Mar 10, 2008 | Televison & Video
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Jul 09, 2007 | Mitsubishi HS-U781 S-VHS VCR
Tape ejects just after insertion
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Dec 19, 2006 | Mitsubishi HS-U760 S-VHS VCR
Televison & Video Logo
269 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
