We have an armstrong furnace that will not ignite. We have taken the hoses off of th pressure switch and blown them out. A technician has replaced the ignitor and checked the smart valve. Any other suggestions?
Did he check the Pressure switch was it filled whit water can you make the switch open on the pressure switch when blowing on it? Is the hose from the inducer motor opened and not blocked ? also if there is a block after the inducer motor it will not Ignite. If the Tech does not know how to check a pressure switch get a new tech.
Csn you check the 5 amp fuse on the Furnace control board to see if its blown?
