Keeps blowing fuse on power board. replace fuse plug it in and it pops the fuse.
SOURCE: Watched a 3hr movie.Started the second movie and
There is a good chance that one or more jugs (CRT)s have leaked coolant down onto the Main bd and Power supply causing severe shorting. At this point ALL of the CRTs must be replaced and the Main bd and or the power supply as well. This is not a inexpensive fix and after the parts are replaced you will need to do a Full Convergence alignment by a very experienced tech which will not be cheap. You might as well purchase a new TV.
SOURCE: samsung hln5065w dlp blows bulbs
The N series, needs to be told via service menu options, what type of bulb is being installed.
SOURCE: I have a Samsung DLP
Lamp , if you have never replaced it!
Mats has them for $99.00 1-800-628-1118
Encompass Parts Distribution has Parts for this Model
and may the free service manual that you can print out online.
They will list PN # /Prices. 1-800-638-3328
I have the same TV as Yours .Had to replace Lamp and Color Wheel on mine.
SOURCE: samsung dlp Hl72a650 wont turn
You could be having a shorted rectifier or shorted chopper transistor . Either way it calls for the work of a experienced service engg:
