Philips GoGear Flash MP3 Player Logo
Posted on Oct 06, 2012
I my gogear vibe wont charge does that mean its broken
5 Related Answers
YourZEN
YourZEN
  • 820 Answers
  • Posted on Oct 29, 2009
SOURCE: Describe your philips GoGear Vibe model
Overview link for the GoGear Vibe SA1VBE04K/17:
http://www.consumer.philips.com/c/portable-video-player/gogear-vibe-4gb-sa1vbe04k_17/prd/us/
Selecting the support tab links to next site:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA1VBE04K/17&scy=US&slg=en
Select under Product support the required software & drivers.
Anonymous
  • Posted on Nov 25, 2009
SOURCE: what video format does gogear vibe use?
well its kinda odd but so far the only format im having any luck with working it is .smv to covnert ur vids to .smv go here" http://www.soft29.com/freeware/smv_converter.htm " hope this helps
oh and btw im not saying there arent more formats but this is the onethat works for mi go gear vibe
aliasger yq
  • 219 Answers
  • Posted on May 31, 2010
SOURCE: gogear vibe 4gb cannot be turned on
check battery voltage
Anonymous
  • 16 Answers
  • Posted on Jun 06, 2010
SOURCE: how to fix power problem of GoGear Vibe 4G
UR MUM
Anonymous
  • Posted on Jun 18, 2010
SOURCE: taking apart a gogear vibe 4gb
I was trying to find a way to take this apart as well, because a soda exploded inside my car while I was away for about 6 hours, and when I came back it was covered in sticky goo, inside and out. After a little fiddling, it was easy to take apart and reassemble.
On the back, remove the barcode sticker, there is a single very small screw. Remove that. You will need a very thin-shafted cross-headed screwdriver. After its removed, take a razor and slide it into the small crack in the casing closest to screw housing, and pop the back off.
After the back is off, there are 4 more screws to remove, 2 black screws near the bottom, and two smaller silver screws on the top, one on each side of the LCD screen. You may need tweezers to remove the smaller silver screws.
After all 4 screws are removed, take your razor and slide it in between the top of the LCD screen and the casing and pop it out. Take note at how it is removed, because it needs to be reinserted the same way.
If you need to remove the directional pad, its a bit tricky. I used my tweezers to pop the two tabs on the left out, and then popped the rest out going clockwise. It takes some time and patience, because the tabs might pop back in.
There you have it. Not difficult at all.
What does file not supported mean on my gogear vibe and how do i change it
Your Philips GoGear Vibe supports these formats:
audio
  • MP3
  • PCM
  • ADPC
  • Audibl
  • WMA
video
  • SMV
audiobook format 4.
More support info:
Philips GoGear MP3 video player SA1VBE08K ViBE 8GB
2answers
My philips gogear vibe is frozen and wont move from screen its on and wont power down, I have pluged it in to see if that will work and nothing, what do I do?
Try the repair function of the Songbird software and restore VIBE to the factory settings. Before you proceed, bach up your files stored on VIBE if possible because the following procedure erases all files you have on the player:
1: Launch the Philips Songbird on the PC
2: In the Philips Songbird menu bar (at the top), click on the Tools pull-down menu and then select Repair My VIBE.
3: Follow the on-screen instructions to complete the repair procedure.
I hope this will help you.
If you haven't Songbird it can be downloaded from Philips website: www.p4c.philips.com/
Thanks
gylacz
1helpful
Batterylife,GoGear Vibe 4GB how long between each charge, getting 5 to 6 hours.
The battery life is rated at 25 hours for audio and 4 hours for video. If the charge is not holding you can try ensuring device is secured while charging. If this does not work the battery is bad and should be replaced. This is not horrible news, batteries for the GoGear Vibe 4GB are only $10.00.
My Gogear Vibe will not charge. It also will not turn on when not plugged into the computer. I cannot access the "charge and Play" option for charging. The language randomly changes between turn-ons from...
I had to re-boot my computer not long after plugging the Vibe in to add some music and recharge. When the computer rebooted it seemed to be dead.
After reading the above I pressed the reset button. It came up again.
Now, here's the crux. After it went through its language questions the recharge message said: Charging. Do not unplug. (Or similar.)
I suspect that the Vibe was deeply discharged. I haven't used it for a while and don't recall recharging it after the last use so I'm not surprised to find the battery deeply discharged.
In future I'll be more careful to read its little messages when I plug it in.
1helpful
My philips gogear vibe will not turn on. it is charged.
when i hold down the turn on button.it would show the philips lable then just shut off. can you help me please.
New GoGear Vibe will not turn on after first charge!
This is not a solution to fixing the mp3 player, but I no longer need assistance, I returned the product for a refund.
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
