It is a front loader am I taking off the pedestal front or the machine? It is a front loader am I taking off the pedestal front or the machine?
AnonymousMar 08, 2009
on my washer when I would start it water would leak out from under it as soon as it started.I removed back panel and when it was filling I found a small hose on the left side near back had a hole in it and that was were the water was comeing from. the tube went to a small pressure switch that told the washer when it had enough water .was real easy fix about 2$ on my washer when I would start it water would leak out from under it as soon as it started.I removed back panel and when it was filling I found a small hose on the left side near back had a hole in it and that was were the water was comeing from. the tube went to a small pressure switch that told the washer when it had enough water .was real easy fix about 2$
I have a Kenmore He3t and it leaks out the bottom while filling. We have to stuff a towel on the left side to soak up water. The post that offered a potential solution is much appreciated. I'm going to look at the hose in the back while it's filling and see if that's where the leak is. Any other suggestions just in case it's not the hose?I have a Kenmore He3t and it leaks out the bottom while filling. We have to stuff a towel on the left side to soak up water. The post that offered a potential solution is much appreciated. I'm going to look at the hose in the back while it's filling and see if that's where the leak is. Any other suggestions just in case it's not the hose?
You can't post conmments that contain an email address.
Re: Kenmore HE3 will not HOLD water, drips out into the...
Check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
1. Turn off the water supply to both hoses. 2. Remove hoses (one at a time so you don't get them confused) 3. On the washer side - look for a removeable screen inside wher you just removed the hose. 4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes. 5. Replace the inlet screens. 6. Re-fit the hose to the machine. 7. Turn on water supply valves. 8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Remove the 3 screws at the back of the machine that hold the top on. pull back on the top and lift the top off. Remove the hose from the inlet valve and remove the screw that holds the inlet valve.
