Question about Nokia 6600
Regarding Nokia 6600
Hi I am using the handset of Nokia 6600 and i am facing a problem.The mobile switches off on its own and there after doesnt restart. if the keys are locked, the mobile switches off faster.Pls assist as the dealer is not able to solve the problem.
Virus
Posted on Oct 19, 2007
  • 22 Answers
Remove the memory card then check.if ok.Scan the memory card with appropriate antivirus software. Then format phone using * 3 call button then switch on your mobile
Posted on May 04, 2007
Anonymous
SOURCE:
I use Nokia 6600. I can't turn on my phone by pressing the switch on button. Is there any alternate key press? I replace the battery but still can't be turn on. If i plugged in the charger cable,...
As you said me that your using Nokia 6600 you need to visit your nearest nokia service center there they will replace you switch but another one after that you wont face any problem .This may take few minutes.You can use your mobile if you follow this simple steps.Take a pen and press that switch on button from that pen try till it get switch on i have use this method went i faced that problem.Thanks for your question happy to help.
Jun 16, 2011 | Nokia 6600
When i enter unlock code in my nokia 6600 it says not allowed pls help
Hi , is the lock for keypad or for the phone itself.
-- If it were just a keypad lock just try entering the code after 1hrs time from ur last try as when wrong code is entered for a couple of times the phone won't accept even when the right code is entered
--If the phone is locked then follow the following steps Just Switch on your Nokia Mobile Phone Handset and Press The Red Button You press to end a Telephone Call.
A Blank Screen Will Display. Now enter "*#06#" in your cell Phone and press Green Button that you press to connect a call.
A Special IMEI Number will be displayed. Just Note Down that on a piece of paper and open a Website
http://www.nokialockcode.com/calculate.php
Inb this website you will be able to find the Nokia Master Key to unlock your Nokia Mobile Phone Handset. enter Your IMEI Number in This Website and This Website will search Through its database and will return you with a Master Key that you will enter in your Mobile Phone handsets to open any Manually Implemented Code.
If u couldn't fix the problem , please elaborate on how the phone got locked .Then i would give another sol
Nov 05, 2010 | Nokia 6600
I am using the handset of Nokia 6600 and i am facing a problem. my handset infected by the virus named by (Commwarrior).By this virus bluetooth is not working and handset is working very slow. Please tell...
The best way is to format by using this..Press and hold 3 keys i.e. Green, dial key, *, Star key, no. 3 , key on keypad and then press the power on/off to switch on the phone.Examine the battery backup of your phone. Remember, do not let go the 3 button i.e * + 3 + green just press and hold keys until you see a formatting word screen shown........But in N series don't release the three button until the time set shown . original system and factory setting has also done automatically.There is no guarantee coz it might not work with some phone...Or flash it.
Aug 10, 2010 | Nokia 6600
Hi, pls send me my license key for ultra mp3 for Nokia 6600
Oct 08, 2009 | Nokia 6600
My nokia 6600 is sending bluetooth messages on it`s own
hi its a very common problem with 6600. u should flash ur mobile from a certified mechenic.OR u must try this method: first switch off ur mobile and switch on ur set while pressing (star key),(dial key or green key)and(number 3 key) till formating screen appear.after appearing formating screen leave the button and let format ur handset.
plzz rate me
Dec 22, 2008 | Nokia 6600
Help
I am using the handset of Nokia 6600 and facing a problem. my handset infected by the virus named by (Commwarrior).By this virus bluetooth is working as all time hidden ON and handset is working very slow. Please tell me how can i solve this problem?
Aug 10, 2008 | Nokia 6600
APPLICATION CLOSE...
There might be a problem either with the program you are using or with nokia 6600 .if you are using facing problem with program try to reinstall that file,but if you think that your mobile is having problem than you can format your mobile or flash your mobile .When you flash your mobile ,it will become new as you you purchased means factory settings....
A. Blank screen phone unable to boot-up. B. Phone is only able to boot-up to “Nokia” screen (may flash “Nokia” 4 times also).
C. Install a program but unable to uninstall it.
D. Unable to delete certain files on C drive. WARNING: This will ERASE EVERYTHING on your phone
If you have any files that are important to you, make backups.
1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your 6600 phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the 6600 phone.
DO NOT let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your 6600 will now be at its original factory settings.Disclaimer: I will not be held responsible for anything that happens to your phone as a result of following my guide. Use this guide at your own discretion and risk.
If this answers your question please rate this as fixed.
If you need more help just add a comment and I'll be glad to help you further... Thanks
dilipbagdi - johny_inmexico@yahoo.co.in
May 11, 2008 | Nokia 6600
Nokia 6600 virus problem
http://www.cell-phone-viruses.com/forum/article47.html
There is a method of redemption for your phone written about there.
Feb 17, 2008 | Computers & Internet
Mobile Formating
No there is no risk in formatting your Nokia 6600. Firstly ensure the battery should charge by atleast 75%, then take out your memory card from the phone . Press * , 3 , OK , all these three buttons simultaneously & Switch-ON the handset while keep pressing all these three buttons. Your phone will start formatting. After formatting your phone will work absolutely normal.
Sep 18, 2007 | Nokia 6600
Formatting
for formatting the handset,you can dial *#7780#....than it will ask the security code you have to give the default code as 12345 or you you can give your personal code which you have given…this will not delete any data from your handset…other way is to do the hard reset that will delete all the data for that youi have to dial *#7370# again it will ask the security code similarly you have to given ealier
Apr 26, 2007 | Nokia 6600
Nokia 6600 Logo
73 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
