Hi, You can unlock a Motorola Droid 2 safer and easier using unlock code. You can get the unlock code for a Motorola Droid 2 from www.wickedunlock.com/motorola-droid-2/rs11wp9/ at affordable cost.
UNLOCKING STEPS FOR MOTOROLA DROID 2
1 - Switch ON your Motorola Droid 2 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola Droid 2 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you
just have to leave the Motorola Droid 2 ON with the errors message and
after 40 minutes to 2 hours the message "Enter Code Special" will appear
again!
SOURCE: got a motorola a956 droid
not possible as of not...most Verizon are CDMA phones...which means excusive only for the origin.
SOURCE: I need a manual for
Copy and paste this URL: http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/DROID2/US-EN/_Documents/Static_Files/DROID2_UG_US_ENG_VZW_68014406001a.pdf
SOURCE: I had bought a Motorola
The solution depends whether you are a verison costumer or not
You are a Verizon customer
1. Make sure your phone line has been active and had no late payment
history for at least six months. If it hasn't, VZW will not unlock your
SIM.
2. Call VZW Global Support at 1-800-711-8300 and ask
the representative for your phone's SIM unlock code. I have already
received one so if a rep tells you they don't have them yet, insist that
they do and/or call back and try a different rep.
3. To test it, you will need a non-VZW SIM. Once you insert it and
power your D2 Global back on, it will ask for the unlock code.
NOTE: It appears that Verizon has put a carrier lock on
the device for US GSM carriers. Therefore until someone figures out a
workaround, you will not be able to use this device on AT&T or T-Mobile
in its current state, even if SIM unlocked.
If you are not a verison costumer then you need to give me full info from where and how you purchased them
