SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
SOURCE: I have a Carrier Aircon.
E5 Outdoor activation of compressor over heatprotection or motor lock
Please clean the condenser coil. And also check out door fan motor rpm. Rpm may be less due to weak capacitor. Replace it.If motor locked you have to replace new motor only.
If helpful, please write.
SOURCE: Carrier Comfort Zone 2 flashing E2
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
SOURCE: Carrier Air V in RV not working - 5 green blinking lights error
Call 1-866-464-2478, Mon-Fri, 8am-5pm. Have model numbers of lower (inside control box etc) and upper unit ready, and I'd ask for technical assistance. Good Luck.
