Have just bought Pixma mx310 everything working except the fax.
I can send a fax and the recipient can received but when they send a fax back it will not accept it I have tried pushing the buttons as quoted in manual. I use BT freestyle 350 phone do I need to program something on my machine??
SOURCE: Fax noise during phone calls
Could it be that sometimes when on phone you acidently hit start/send? Check it is set to manual answer too, slight possible call waiting problem, outside chance previous storm damage has hurt modeum board
SOURCE: canon mx310 fax noise
Ok, I think I have found a solution.
I have read all the posts on the net and with no success I decided to go againts the grain.
After I set all data to default:
Set printer to "Fax priority mode" and set Ring count up to enough that you have time to pick up.
It rings the amount of rings you set it to and then makes a beep sound in the caller's side. It then continues to ring on the printer and asks you to press stop if you want to use handset.
I am still testing this.
SOURCE: No dial tone detected
It may be a bad modem on the copier. Plug your phone into the auxillary phone port on the copier and see if you get a dial tone. Also make sure that your cord from the wall is plugged into the line port and not the phone port.
SOURCE: Can't fax from Canon Pixma MX310
I spoke to BT, they sugest to put filters on anything which you vconnect, i know that it doesnt make any sense but they said that once youve got broadband connected to your line, all you connect next has to have a separate filters. try it out as i dnt c any other methods. It worked for him by the way!
Faxes machines are capable sending and receiving data documents. First the sender sends to another machine details providing the return addresses. Requetsing the receive to reply the to the fax also requires providing fax numbers.
