Got new handset which was registered with another base. I need a way to reset the handset so I can register it to my base.
The secret decoder key sequence, provided by AT&T tech support, to factory reset this handset is:
(right softkey "-") * 3 3 1 7 3 4 # (left softkey "-")
The handset they should beep and go into registration mode.
Per AT&T service, to manually reset your TL86009 handset:
how to manually de-register your TL86009 accessory handset.
Here's how:
When phone is idle, Press *331734# then left - upper softkey (Menu/Select)
SOURCE: How to de-register handset from
First deregister all handsets:
Step 1: At the base, press MENU, scroll to BASE SETTINGS, then press OK.
Step 2: Using the base dialpad, enter * * 3 3 5 7 8 2
Step 3: Re-register each system handset:
At the base, press MENU, scroll to DISPLAY BASE-ID, then press OK. The 15-digit base ID number will be displayed.
Step 4: Using the handset dialpad, enter the base ID number. Repeat the registration procedure for each system handset. Each handset is assigned a number in the order of registration
SOURCE: 2355 at&t phone
you will need to call att or manage your phone online at http://www.att.com/gen/landing-pages?pid=3308
SOURCE: AT&T EP5632 phone won't register or find base.
I had the same problem happen to me as well and I took the batteries out of all handsets, and unplugged the base for a few minutes. Then plugged in the base, reinstalled the batteries and it registered all handsets lickety-split. Hope this helps you.
SOURCE: I need to de-register an
When the handset is searching for the base, click the new button, then enter the 15 digit base ID number into the handset.
I have the same problem. There seems to be no way to reset the handset or make it forget the old base.
I have the same issue. There seems to be no way to reset the handset or make it forget the old base.
I contacted AT&T tech support and to my utter shock and amazementthey provide the secrete decoder key sequence to reset the handset.
The key sequence is * 3 3 1 7 3 4 #
For some reason this interface deleted some of my text above. It is (right softkey "-") * 3 3 1 7 3 4 # (left softkey "-")
Thanks-Its worked!
