Sears sell chuck keys in all of the common sizes, of which there are only a few. If you have the old key, take it with you. If you don't have the old key then find the diameter of the three holes in the chuck (easy way to do this is to see what size drill fits into those holes) and measure as closely as you can the diameter of the gear you need. This is tapered, so measure (and double) the distance from the center of one of those three holes to the bottom of one of the gear notches on the ring on the chuck. You could also take the drill to the store with you!
SOURCE: Replace drill chuck on 23 year old Craftsman 8" drill press
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
SOURCE: Hello, I am trying to locate an exploded diagram
Here's a link that may prove helpful to you. I'm in the US and resources for Fobco seem a bit slim...
but click here and and possibly here and good luck!
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: Craftsman 10" bench drill press chuck wobbles
If this is a new tool I would take it back and get it replaced. The only other way to eliminate this problem is to determine if it is the spindle or the chuck and replace the defective unit. Warranty works better.
SOURCE: hi, I have a Clarke Drill Press Model No:- CDP 12HBN
You can get a universal chuck key at Home Depot, Lowes and many other tool outlets. They have 4 different keys in one.
SOURCE: i need a chuck wrench/tool for a duracraft drill press
Are you talking about the chuck key? That's the little wrench with a collar of gear teeth on it.
There are only a few standard sizes plus a couple of odd-balls. Last time I looked, Sears carried a good selection. If you have the old one, take it with you to the store. If you don't have the old one, find a way to measure or approximately measure what you need. Another chuck key that doesn't fit can be a useful reference. If you can find something (maybe a drill bit) that is a close fit into one of the three holes in the chuck, that can be useful too.
