SOURCE: Need to remove links in metal watch band Fossil 10
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start
with a tiny screwdriver and unscrew one of the screws. If it turns, but
doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take
a hardened steel needle and blunt the sharp end to the approx. size of
pin end diameter using any sharpening stone or sandpaper. Get an old
towel and fold it to make a soft base for work (like small cusion). As
you don't have a special bracelet holder you will need a pair of
helping hands to hold the bracelet steady upright. You will need small
hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be
driven split end out first, not vice versa. Make sure that the grooved
pin ends are facing towel, not the needle and hammer!!!
Now place
the watch on the folded towel, take that needle and smallest hammer you
have and start driving the pin out using light blows. Do Not hit hard,
as you will brake the needle, scratch your watch or even injure
yourself. Watchmakers are using 45 gram hammer, so, calculate your
strength of blows.
After a few blows check if the split end is
coming out and when you see that the end is long enough to grab it with
pliers, pull the pin out with pliers. When pulling, do NOT turn pliers,
as pins tend to brake when twisted. Use firm grip and your strength to
pull the pin without twisting.
After shortening the bracelet or
adding extra link(s) make sure that the pins go back EXACTLY the same
way as they came out- the blunt end first in the hole and the split
(grooved) end last. Before doing that check remaining pins in bracelet
to make sure that you put them back from the right side of bracelet.
It
is recommended to use plastic hammer to drive pins back in or you will
scratch or damage bracelet. If plastic hammer is not available use an
old toothbrush handle (or some plastic item) as an absorber. Simply put
pin into the hole as deep as you can with your fingers, put the
toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
SOURCE: reduce size of band for fossil 10 atm
how to set my FOSSIL 10 ATM watch... I should set the date and the day with only one button plss
SOURCE: How do i set the time on a Fossil 10 ATM watch?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all FOSSIL watch manuals.Rate me, please..
SOURCE: can the glass piece of my fossil 10 atm be
Yes, it can be replaced.
Just head down to the nearest Fossil store and they will help you do it. If it is still under warranty, it will be free-of-charge.
SOURCE: are fossil 10 atm watches
No watch is "water proof." As a matter of fact, there's a U.S. law on the books that watches (and other equipment) can only be described as "water resistant," since nothing other than a solid object can completely shed water.
All that said, the 10 ATM designation is meant to convey that when the watch was new, it was supposed to withstand up to 10 atmospheres of external pressure--which would translate into being about 300-330 feet underwater. That's pretty water proof in my book.
HOWEVER, and this is a big caveat, a watch's water resistance rating is based on its condition at the time that it left the factory. Over time, the little gaskets that help keep water out of the watch will begin to wear and provide less water resistance. In particular, official factory servicing states that the neoprene gasket between the case and caseback of the watch should be replaced every time that you change the battery. In fact, most people, including me, re-use that gasket if it still looks pretty good when I open the watch. That definitely compromises the factory water resistance rating.
Bottom line: If you have a watch rated for 10 ATM of water resistance that's a few years old, I wouldn't be all that concerned about getting it casually wet, or even going swimming with the watch (I'm paranoid enough that I wouldn't do this, but I'm probably in the minority). However, I wouldn't go diving with a watch that's had its battery replaced unless it was re-tested for water resistance after the battery was serviced. Some but not all jewelers have special machines that perform this test. If you're interested, you could probably pay one of them a few dollars to have your watch tested. They don't have to do anything to the watch other than place it in their machine, so it's not a big deal for someone who has the equipment to perform this test.
