Turn over router and check in the bottom default access IP address and then type that IP address in to your browser. Then it shall ask you for ID and password. Enter `Admin` or `admin` as ID and `Password` or `password` as password. You will see a web based setup opened in front of you. Go to the Wireless Lan settings and then you will SSID so change the SSID and this would be your network`s name. Then go to subsection security and select WPA2-PSK or simple WPA-PSK then enter your desired network key. Once done with all these things the click apply and reboot if prompted.
Here's how to change your Gmail password:
If your password isn't working, you'll need to go through our password recovery process. Google Apps users, please contact your organization's IT admin for help with password recovery.
sneha murty
What password did you forget? to your SSID password (when attempting to connect to the network) or to your router's setup through the web-based setup page?
