Error message says "Program have not found current paper stock among stocks supported by printer. Here is a list of supported Paper Stocks. Program will use default paper stock." (OK) - but when I click OK it does not print.
Three readings are required:
.No Media
.Lable Backing
.Backing plus lable
Standard Calibration
Step Operator Action Displayed Message Comment
5 Press the key. SENSOR CALIBRATION
PERFORM CALIBRATION
You are beginning the standard
calibration procedure.
6 Press the key.
Remove the media from the
Media Sensor then press any
key.
REMOVE LABEL STOCK
PRESS ANY KEY <yyy>
This sets the parameter for the
'empty' value.
Where 'yyy' is a numerical
value representing the current
sensor reading.
7 Proceed according to your
media type:
Die-cut stock: strip the media
from the backing and then
reinsert it into the sensor; adjust
the Sensor Eye Mark over the
center of the backing.
Notched stock: adjust the
center of the notch.
Reflective stock: Adjust the
center of the facedown black
mark.
Continuous stock: go to Step
8.
Press any key to continue.
SCAN BACKING
PRESS ANY KEY <yyy>
Or, for reflective media:
SCAN MARK
PRESS ANY KEY <yyy>
'gap' or 'mark' value.
sensor reading: useful in
locating the best sensor
position.
ã Note: Never position the
sensor over a perforation when
recording a sensor reading.
ã Note: Do not move the position of the Media Sensor after it has been adjusted.
8 Position the label (and backing,
if any) under the Sensor Eye
Mark.
ã Note: If using preprinted
media, ensure the label area
under the sensor is free of
preprinted text, graphics or
borders.
SCAN PAPER
PRESS ANY KEY <yyy>
'paper' value.
sensor reading.
Maintenance and Adjustments
5-3
Standard Calibration (continued)
9 Observe the display. GAP MODE
CALIBRATION COMPLETE
REFLECTIVE MODE
Or, for continuous media:
CONTINUOUS MODE
The calibration was successful.
See note below if another
message was displayed.
10 Exit upon successful
calibration: Back out of the
menu tree by repeatedly
pressing the key.
If using gap or reflective media,
press and hold the FEED key.
The printer will begin
advancing media; allow at least
one label gap (or mark) to
advance under the sensor.
READY
The printer is now ready to
begin printing.
The traditional method --- uninstall Broderbund Calendar Creator with windows add/remove program
1. Start-->Control Panel-->Add/Remove Programs.
2. Find Broderbund Calendar Creator in the program list and right click to choose Delete.
3. Follow the panel wizard and reboot your PC when it finished.
In fact this way can not remove all the components of Broderbund Calendar Creator. Registry keys of Broderbund Calendar Creator still remain on your computer. It is advised to clear up registry entries of Broderbund Calendar Creator or you are likely to encounter problems like uninstall or install error, registry error and so on.
Guaranteed Method -- Uninstall Broderbund Calendar Creator with a professional uninstall tool
A third party uninstall program can force uninstall Broderbund Calendar Creator while windows add/remove program fails. Moreover, a third party uninstall program can clear up all the registry entries of Broderbund Calendar Creator. Among so many uninstaller tools, Perfect Uninstaller enjoys high reputation. Perfect Uninstaller can remove Broderbund Calendar Creator completely in 4 simple clicks.
1. Free download Perfect Uninstaller form its official website.
2. Install Perfect Uninstaller on your computer
3. Browse for Broderbund Calendar Creator folder with Perfect Uninstaller.
4. Click REMOVE to uninstall Broderbund Calendar Creator from your computer.
It is important to uninstall Broderbund Calendar Creator thoroughly from your computer, as its remained components will have a side affect on your current antivirus program. Are you tired of trying various methods to uninstall Broderbund Calendar Creator? Do you want a certain effective way to uninstall Broderbund Calendar Creator? What you really need is a third party uninstall program. And before you search for a great uninstall program, have a look at Perfect Uninstaller and then compare it with the other one
Read more: http://www.articlesbase.com/software-articles/how-to-uninstall-broderbund-calendar-creator-thoroughly-from-your-pc-now-3769861.html#ixzz1CrBj3PaU
Under Creative Commons License: Attribution
