WHAT DOES THE KEY ICON ON DASH MEAN? MY CAR IS STALLING DOES THIS HAVE ANYTHING TO DO WITH THE KEY ICON. 2000 JEEP CHEROKEE LIMITED
The symbols should be explained in your owners manual. The symbol could mean that the key you are using is not recognized by the controller as being the correct key. I think this would not allow the vehicle to start at all. Are you using a key that is a copy obtained from anywhere besides a Jeep dealer? The keys have a chip in them that must be programmed by the dealer. If you are using the correct key, I would have the SKIM module checked.
SOURCE: 2000 jeep grand cherokee limited starts in 3rd gear
oil pressure problem should be checked independently of other problems...Use a good accurate mechanical gauge to check. If pressure is good (no less than 15psi at idle hot (I prefer to see at least 20) check dash grounding, block ground and if OK, change sending unit. Dash and body ground can influence operation of shift and body control modules so indirectly your problem may or may not be related, depending upon what you find while testing. And it could turn out to be a defective module! They are expensive and just plugging new ones in may work, but then again, it might not. I might be totally incorrect on this...that's the value of actually being there instead of doing this by "remote control".
If you read the numerous posts pertaining to all vehicles, you will see that you are not alone with electrical problems...As long as the engineers who design this stuff, keep using "modules" to replace ordinary simple and reliable systems, we will continue to have these problems. Do some testing and I'm sure you will find a solution! (I'm still waiting for someone to make a program for a PC that will give a complete readout of every system in a vehicle, including exact faults instead of general system "suggestions")
Good luck
SOURCE: 2000 Jeep Gr. Cherokee 4WD 4.7L under dash fuse diagram
If you still have the pop off cover for the fuse box the amperage and position (number) along with the purpose served by each fuse is stamped on that cover.
SOURCE: 2000 Jeep Grand Cherokee Limited Fuel Filter
Sorry brother, it is in the gas tank with the pump. they used filters that are suppose to be good for the life of the vechicle. you can see the plug if you lift up your spare. hope you dont HAVE TO go in there.
SOURCE: Very rough idle on 2002 Jeep Grand Cherokee Limited Edition V8
If you haven't changed the plugs or had the fuel system cleaned, now would be a good time to do it. The number 1 culprit for rough idles is dirty injectors or plugs. You can try an injector cleaner in a can (or bottle) for under $10 and see if it helps, and then work from there. If there isn't any improvement then if you are able to, check the plugs for any gunky buildup and if you find a bad plug, make sure you replace them all (or have them replaced) at the same time.
SOURCE: 1994 jeep grand Cherokee limited......stalling
Hi, You may have a defective ignition coil or a glooged fuel filter and/or fuel pump. it is hard for me to say at this point. What is the fuel pressure? Are there any trouble codes pulled from the PCM?
