Televison & Video Logo
Wasiu Posted on Oct 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Helo sir, i have a L.G T.V. Model No kf-20p32... the output voltage is normal. But it keep on blowing the horizontal output
Todd Hill
Level 2:
Sergeant:
Champion:
  • Expert 433 Answers
  • Posted on Oct 02, 2012
Todd Hill
Expert
Level 2:
Sergeant:
Champion:
Answers
433
Questions
0
Helped
398920
Points
665
ARE YOU USING A 2SD OR 2SC, CK 1MIC CAP if shorts imediatley bad flyback
1 Related Answer
Anonymous
  • 998 Answers
  • Posted on Nov 22, 2010
SOURCE: I have a sony kv32fs120
try to check the capacitor 250volts 10 microfarad and the zener diode
2helpful
Sir, why does the transistor d2499 getting too hot when the tv is operating? If it is normal or not?
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
My TV model no lg29fe5rge when we switch on the tv .why my tv horizontal output transistor(c6090) is blowing off??
1helpful
Panasonic tv EV051 keep on blowing horizontal transistor
There are many reasons for this fault. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sir,I have a problem with a Bpl 21 inch CTV old model.output voltage is fine but when I press stby key it starts to work but in a second it turns to standby mode.so how can I solve this problem.
Power supply problem
WHY H-OUT blowing off
If the Flyback Transformer [FBT] is bad, it can happen. If the DC output voltage from its SMPS is abnormal [higher than normal] this can happen. Contact any service technician.
3helpful
Helo sir, i have a L.G T.V. Model No kf-20p32..is blowing the horizontal output..i change the flyback tranformer ,bt is still blowing the horizontal output
Check all the capacitors connected to horizontal output transistor. Especially one connected with its collector to ground. a high voltage [1.5Kv]. capacitor. Replace them. Check for any short inside the winding of the yoke. It is difficult to detect the winding short inside the yoke. Connect an other yoke in place, after pulling out the CRT base card out of the TV. This you can make sure about the condition of the deflection yoke.
1helpful
Hi,im a technician and i got a problem with a Sony Trinitron Colour television model Kv-T29mn3. I replaced an Str, capacitors & Horizontal Output Transistor. Voltage output its okay but it keeps on...
These sets had alot of problems with bad FBT flyback tranfomers,You might need to change FBT.
Heres another thing they also had Bad Picture Tubes that will blow hori output and you will not know its the Tube untill you replace the FBT.Use a high voltage probe to monitor Voltage coming from the anode button, if you dont have a HVP then disconnect the CRT board and monitor set.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
