Lid sensor
In your control panel look for your power setting control. In there you will have multiple items one of them will be "what to do when I close the screen on my computer" Set this to "nothing"
Windows 7 and (I think vista)
To get into the control panel click: Start > Control panel > system and security > Power Options On the top left you will see a few options, you should see it there.
SOURCE: I don't know where the wireless button is
Call HP and speak to one of there tech. and I am sure they will tell you right away. It is usually on the right side or right in fromt of the computer. It is very small and it moves one way to the right and one way to the left. Left is usually off. Hope this helps,,,Good Luck,,,Darren
SOURCE: driver for HP Pavilion DV6 for Inbuilt webcam Driver
Go to cyberlink.com download driver, you can also use Skype. Just remeber to check what version you have, this should be found in the manaul. Hope this helps
SOURCE: Low volume on my HP Pavilion dv6-1245
Open the audio panel (settings -> control panel -> Sounds and audio devices -> volume). Check that the volume slide is all the way to the right. Also, click on the "speaker volume" button and check it is all the way to the right
SOURCE: HDMI, and VGA on HP Pavilion dv6 1359wm, S-Video
you need something like this http://www.amazon.co.uk/VGA-to-S-Video-RCA-Adaptor/dp/B000P3UB24 - but you may also need to see if the VGA display adapter supports the output, sometimes this also needs to be enabled to get it to work - other times it works just by using the VGA output switch - which will be one of the F keys look for a symbol of a screen and then use that F key and the FN key together to toggle the output from
<laptop only><laptop and VGA output><VGA only>not necessarily in that order.
The HDMI is a digital signal out and to convert to analogue for the TV will need an expensive convertor
Testimonial: "Thank you, they are digital TVs, just not HD, So still gotta go VGA."
Please specify the operating system you are using (windows version etc) and also the reason why you wanted to disable so that we can provide you with appropriate steps.
