Question about Thermador SGS36GS Gas Cooktop
Extra low burner that won't ignite
From your explanation of my non-igniting cook-top burner it may very well be the potentior. Would that explain why there is no evidence/smell of gas when it is turned on? What is the potentior and where is it to fix/unclog, or change it? Thanks... I have the same problem. Can you tell me how to separate the top from the burner box? Also, when I try to push the cooktop up to disengage it from my countertop, the burner control side (right) doesn't seem to want to give. Is there something connected in there or is it just sticky? thanks
2 Suggested Answers
6ya staff
SOURCE:
xlogas
  • 3 Answers
SOURCE: extra low burner that won't ignite
Solution is a lot simpler. Please click on this link http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/20666-no-gas-xlo-burners.html#post62329
Posted on Mar 26, 2009
New Maytag MGC7430 gas cooktop leaks gas when lit
First it could be leaking from the control knob when it is on . There could be a leak at the base off the burner letting out gas or on the burner line . You need to get back on to your installer or where you purchased the cook top . This basic gas fitting leak detection .
Jun 15, 2017 | Maytag Cooktops
Clicking of igniters continues non-stop unless I unplug the cook top.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
Sep 25, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
My ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium.  If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas.  After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up.  The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel.   Lift off and unsnap the casing of the problem igniter switch.  The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
Apr 02, 2009 | GE Cooktops
Whirlpool Cooktop Burners do not light
Hi Scott,
Please view the link and videos below.
http://producthelp.whirlpool.com/Cooking/Cooktops/Cooktop_Product_Assistance/Cause_of_gas_burners_not_igniting%2C_lighting%2C_clicking_or_ticking
Searching youtube can often provide many helpful videos that clearly explain how to repair such issues.
Good Luck.
Jun 02, 2017 | Whirlpool 30 in.GLT3057 Gas Cooktop
Gas burners lit, but electronic ignition still clicks
heatman101
fsggfs
Mar 13, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
Lowly what the potentior does is turn on the burner control system. When you turn on a normal burner you are opening a gas valve and closing a switch to generate a spark. Thus gas flow to the burner and spark. On the extra low simmer burner there is a electric solenoid between the burner head and the gas valve. this has to open as well for gas to flow. What the potentior does is signal the simmer control what level of flame you are requesting and telling the spark module to generate a spark. Once you go to the exlow setting the potentior tells the simmer control what level of heat and will cycle the flame on and off. So when the burner knob was between low and extra low, the flame would cycle on and off. You have to seperate the top section of the cooktop from the burner box to change the potentior for it sits on top of the gas valve for that burner.
Aug 10, 2008 | Thermador SGS36GS Gas Cooktop
Clogged burner on gas cooktop
lowly is it the left burners that won't lite? I only ask as depending on the model some of the Thermador cook tops had simmer control burners. This is a 3 part system on the burners. 1 a simmer control, 2 electric solenoid, 3 potentiors. When you turn on the burner the potentior tells the simmer control to send power to the gas solenoid. At the same time the unit will spark. If your unit has extra low on the left 2 burners then you have this system. The usual problem in the potentior. Hope this helps.
Aug 07, 2008 | Thermador SGS36GS Gas Cooktop
Gaggenau Cook-top VG 352-812 problems
Hi, interesting. I have the same units on my GasHob and my problems are exactly reverse. To turn the burners on it takes about 15 clicks and with some luck you'll get gas! Sorry, wished I could help.
Claus.
Jun 08, 2008 | Cooktops
Thermador SGS36GS Gas Cooktop Logo
130 people viewed this question
Top Thermador Cooktops Experts
jasbo
jasbo
Eric Gundersen
Level 1 Expert
ray gallant
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
