Really simple! I have been trying to just set the correct date on my women's 1440 sports watch , but can't. There are only 3 buttons: on the left is the MODE; on the right are ST/STOP and LAP/RST. Please help me thanks!
If not in the time mode, press mode to get to the time mode.
While in the time mode, press and holdlap/rst for two seconds.
The seconds will begin to blink.
Press st/stop to reset seconds to zero
Press mode and the minutes will begin to blink.
Press st/stop to advance the minutes
Press mode and the hour will begin to blink.
Press st/stop to advance the hour
Press mode and the day and date will appear. The day will blink.
Press st/stop to advance the day.
Press mode and the month will begin to blink.
Press st/stop to month the minutes.
Press lap/rst to return to normal state with you new settings. You can hit lap/rst to return to normal state at any time in the process, for example if you only want to set the minutes, just hit lap/rst after you set the minutes.
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
To set the right date on your timex, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
To set the digital time and date on your Timex, please follow the steps below.
Timex Digital Watch
Setting My Timex 1440 Sports Watch
(4-button) 1. With the time and date showing, press
the top left button. 2. Press the right top button (this sets
seconds) 3. Press the bottom left button. This flashes the
symbol for am, pm will show if pm). 4. Press the bottom left
button, minutes flash. Press the top right button until correct minutes. 5. Press the bottom left button, month flashes. Press the top
right button until correct. 6. Press bottom left button, date
flashes. Press the top right button until correct. 7. Press
bottom left button, day flashes. Press right top button until correct. 8. Press bottom left button, time format flashes ( now it can be set to
Timex Digital Watch
Try to pull the roll handle up a little until it clicks, then, usually anti ~ clockwise will set time only, clock ~ wise will set date. This should solve 'em. :)
same problem here! please help!
i have the same problem as Vicky, it is another brand, but my watch also has only three buttons.
Thanks!
