Over the last while my monitor started showing noise on the top of the screen, it looks like lines (wavy or not) and it has progressed along the whole screen. It is ok when viewing just the wallpaper with a lot of colours and darker, but gets worse when opening a screen with a lot of white in it, to the point that it is unreadable. I tried an old fashioned CRT, and that worked fine, exchanged the cord, with no difference. And when I turn the monitor off and on again, it is good for about 5 seconds, then it comes back. It does not look like my computer, but seems to be the monitor only.
Re: Severe noise on monitor when viewing white area
Although I still have the problem to a slight extent (very slight wavering of the vertical lines going from dark to light or white) reducing the contrast from 100% to 80% seemed to do the trick. Although this monitor is on the way out, it has lasted about 7-8 years now, at least it will keep going for a while.
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
Amazon.com, Inc.
Rating: 3.8 - 1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
I'm afraid only a technician can repair this. Perhaps some parts must be replaced.
If the camera still makes good pictures, perhaps you better learn to live with the lines. Check is the white lines appear on an image you view on your computer. If so, the sensor or processor is damaged. Then you better start looking for a new camera, because that will be cheaper than to repair you S4300
do if only if u r a pro in handlin monitors..dis is a typical problem of 'dry-sould'..plz don't tap much n fix it at d earliest or it may damage other parts inside..u gotta re-sould throughly..if itz a laptop u need to change d inverter circuit n ccfl....
The white glow with no picture means that either the ribbon cable connection between the logic board and the monitor has come lose or dirty contacts, or the LCD Controller (T-CON) board (part of the LCD panel is not getting 5v or 12v depend on LCD panel from the logic board or the LCD controller board has blown fuse, see pictures here for guide (note pin on the LCD board with arrow mark is pin 1 and is the incoming DC power supply line): http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/?action=view¤t=DSCF0881.jpg
You may also want to look for bad caps (bulging top) on the logic board. There should be 5vdc feeding the logic board also.
Open this link and make it full-screen. Watch the screen for 20 seconds or so to see if the line of lit (white) pixels remain.
If this line remains during this, and even when the the computer is first starting up, it is most likely a row of "lit" pixels caused by a faulty connection or circuit inside the display.
While you can sometimes rub the area of the screen near a single lit pixel, an entire line of them usually denotes a more complex problem that can only be fixed by having parts replaced by a technician
Note: Be sure all of your cable connections are securely fitted, and that the line is there no matter what is displayed on the display (especially at the boot screen before Windows loads).
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
sounds like you have what are called dead pixels. This typically happens in monitors that are about 2+ years old. If you are still within warranty i would contact hp about getting it serviced.
