SOURCE: Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
SOURCE: I have a WD My Book 1 TB external hard drive. It
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly. 5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SOURCE: Western Digital External Hard Drive Won't Boot Up
Take it our of the external encasing and plug it in directly to your motherboard. This has worked for me in the past. I just had my second wd external harddrive crash so now I will do the same process all over again.
SOURCE: Elements by WD, AC Adapter Failed
There are replacement models for this 5V/1.5A power supply that the AD6008 uses.
One of them is made by a company called "Asian Power Devices" [APD] and their model number for the replacement for this particular unit is: DA-30C01.
I've seen them for sale on www.amazon.com for around $25.00.
Testimonial: "Thank you very much. That's eactly what I was looking for. I appreciate you speedy response."
