Question about ACDelco 3,500 Watt 6.5 HP OHV Portable Generator, CARB Approved #AC-G0002
Generator 13 hp carb
Squirt fuel in carb it runs but then quits running
    Sergeant:
  • 333 Answers
Hello Parker, I think Steve is spot on. I am impressed by his detailed and accurate explanation .
Posted on Oct 12, 2015
  • 3,289 Answers
These are generic suggestions for small engines that will not start or run under the conditions you described in your question.
Engines that do not run often can often suffer from the use of stale fuel. Be sure the fuel is fresh. Drain old fuel and if not a very large quantity, you could mix with fuel in another tank (such as your automobile) that is used regularly and quickly or dispose of properly. Many fuel retailers have different formulas for fuels sold in different seasons of year that work best in the seasons in which they're sold. it's not to say a summer fule won't burn in the winter - but that a winter fuel will burn better in winter. Add fuel stabilizer to help keep gasoline in tanks of seldom used engines from growing stale.
Many gasoline powered small engines incorporate a "fuel shut off valve" either at the bottom of the tank (near the fuel hose connection) or an inline type valve on the fuel line itself. Make sure the valve is on - many times this means the handle is inline with the hose instead of perpendicular to it.
Have a look at the carb linkage. The linkage consists of the metal rods & springs that provides positioning of the carb components that increase and reduce the speed of the engine as the load changes to help maintain a steady output. The moving parts of the carb should not be gummed up or dirty and should move easily & freely. Use of carb cleaner products are ideal for cleaning these areas. Spraying cleaner into the throat of the carb will make starting difficult and as per instructions should be done in short bursts only while the engine is running. Do not attempt adjusting the screws on the carb as these are factory set and under most circumstances need no further adjustment.
The next thing to check is the fuel and air filters. If the fuel is old or has become clogged, it will be necessary to replace it. These filters are located between the fuel tank and carb. Many are located inline on the fuel hose. You should shut the fuel shut off valve if it is between the tank and the filter to prevent fuel from draining from the tank when the filter is removed (or have a container ready to capture the entire contents of the tank). The air filter usually becomes clogged before the fuel filter will - depending if it is operated in a dirty / dusty environment or not. You may be able to wash a sponge filter or use compressed air to clean a paper filter by directing air / water streams opposite of the normal airflow direction. Older foam filters will likely break apart and require replacement and paper filters contaminated with oil (unless designed to be in oil) may not clean up enough to allow enough air into the carb and require replacement.
Hopefully, one of these suggestions will work for you. Otherwise, it may be time for a professional small engine tune up. Good luck!
Posted on Oct 06, 2012
6ya staff
SOURCE:
Coleman 1500 generator with 132 cc Kawasaki engine will not start clean carburetor,new plug,fuel,oil, has spark
Remove the air cleaner and give a couple of quick squirts of starter fluid into the carb.
If it runs for even a little bit, you have a dirty carb not delivering gas.
Re-clean all the orifices under the fuel bowl.
Sep 30, 2017 | Coleman Electrical Supplies
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Generator will crank but will not start
First check spark while cranking over( pull the plug wire hold by insulator about a 1/4 inch away from any ground, you should see a strong spark. then check to be sure the fuel is pumping from yhe carb., if no fuel try a short squirt into the carb intake. should fire up if you had spark.Its generally a good idea to put in a new plug and be sure to check the gap.
Oct 01, 2013 | McCulloch 11 HP 5700 WATT GENERATOR
I have a 1993 Ford F600 gas powered truck that will not run. With the fuel selector set on either tank neither of the tank mounted electric fuel pumps run. If we squirt fuel directly into the carb while...
some factory fuel pumps are ground controled off of negaitive battery cable. check connections and if cable full of acid. replacement of cable recomended.
Dec 16, 2012 | Cars & Trucks
I've got the 1850 Pulse which I can't get it to run. I've cleaned the carb 4 or 5 times, and cleared holes and jets with a fine wire. New gas in tank, plenty of gas flow to carb. I can start with gas...
Harold, it sounds like fuel based issue, have you checked the screen on the fuel tank? this should be a gravity feed, and not pumped fuel...Try an external fuel supply, for testing purposes....
Mar 02, 2011 | Coleman 1850 Watts Generator Each...
Hello, I'm trying to get an old Coleman Maxa 5000 ER Plus to work again. The interesting problem is that i can get it to start and run, IF i squirt gasoline into the carb throat with a squirt sprayer, but...
First make sure you have fresh gas in the tank, as old gas can cause a 'no run' condition. Once you have fresh gas in the tank, make sure the gas flows freely all the way to the carb by removing the fuel hose from the carb inlet & checking for good flow (bad shut-off valve or obstructed hose by debris could cause same problem). Once you are sure that good, fresh gas is going into the carb w/o obstruction, remove the lower bowl from the carb - carefully - do not lose ANY parts, starting with the washer on the bolt. With fuel flow 'ON', fuel should flow freely when this bowl is removed, so shut off fuel valve in the hose. Now, if you carefully remove the bolt / brass tube from the center of this bowl area (center of plastic float) - remove bolt downward, like you would a lightbulb from the ceiling - this bolt should have several holes in the side, they are probably clogged, so unclog them with a needle or wire, wipe clean, and reinstall. That probably just solved all your problem.... if not, you likely will want to replace the carb completely, as it is not very expensive, and will surely solve your problem. *** Be careful with gas fumes !!! ***
Dec 21, 2010 | Coleman Powermate Powermate 5000W...
I have gas shooting from the carburater directly into the air filter and subsequently leaking out onto clothing and bike. Any ideas what makes this happen.
Your carburetor is equipped with an accelerator pump that shoots a squirt of gasoline into the carb when you twist the throttle. There is a brass nozzle located in the very front of the throat of the carb that squirts the fuel. This nozzle is supposed to be positioned to squirt the fuel inwards into the carb. Is there a chance someone has turned this nozzle. If you look at it very closely, you can see the small **** or hole that the fuel comes out of.
Now, are you running your bike without the air cleaner on the engine. Although the accelerator pump nozzle should be set to direct the fuel into the carb, the air flow generated by the running engine should be pulling the fuel into the carb as well.
If you've got gasoline coming out of the carb and the engine is not running and you're not cranking on the throttle, you've got a problem with the needle and seat in the carb. Probably a piece of trash caught in the seat. You'll need to take the float bowl off of the carb to fix this problem.
You could also have a bad diaphragm in the accelerator pump. If the diaphragm gets a hole in it. fuel will flow up the tower that the accelerator pump actuator rod goes down into. While you've got the float bowl off, go ahead and replace this diaphragm for the accelerator pump as well. They're not that expensive.
Good Luck
Steve
Sep 19, 2010 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
Acts like it is not getting fuel
Check the fuel line to see if it is clear. Run a wire through it or blow it out with air. Then if it is ok check the fuel tank to make sure nothing is clogging the fuel there. (Sometimes over the years debris gets into the tank and can clog there.) Had an old mower that did the same thing you are talking about, start and then quit. Had to clean the fuel tank out and then it ran like a champ. Good Luck
Jun 10, 2009 | Coleman Sport 1850 Generator
Won't continue running
This unit has a fuel solenoid on the carberator, which opens to allow fuel to the carberator. Check to see if this solenoid opens while cranking.
May 07, 2009 | Electrical Supplies
ACDelco 3,500 Watt 6.5 HP OHV Portable Generator, CARB Approved #AC-G0002 Logo
135 people viewed this question
Top ACDelco Electrical Supplies Experts
Gene Haynes
john h
Are you an ACDelco Electrical Supply Expert? Answer questions, earn points and help others
