Model:1209 type:rh-105 code:0560687 imei;355224/03/913886/9
SOURCE: forget new security code of my nokia 1600
Hi Friend,
Kindly with your Master security code for the IMEI number provided
1262525742
or kindly check it in the below mentioned link
http://mastercode.nokiafree.org/
or it these all not supported then kindly inform it to your service provider,they will make a reset to your security code from their back end process,since they keep all the codes in a secure manner.
Kindly check it and provide the status
Regards,
Ayyasam
SOURCE: FORGET MY SECURITY CODE
hi there,
IMEI: 357077006216748
Security Mastercode: 3773206630
Good Luck!!!
neo
SOURCE: Don't worry there is Solution
Hello, note that,12345 is the factory master code for nokia.
If fails, get the code at www.nfader.su
If still fail , get it unlocked at www.unlock-zone.com
Regards, J
SOURCE: i forgot my nokia 1209 RH-105 security code. IMEI
dont worry, just follow the steps below:
note: u need to have a pc running xp
click to download NSS
http://www.b-phreaks.co.uk/NSSDownloadLanding.htm
TO RECOVER THE CODE
1. CONNECT UR FONE VIA USBCABLE IN PC MODE & INSTALL THE DRIVERS FOR UR CELL FONE PROVIDED WITH NOKIA PC SUITE.THEN EXIT PC SUITE
2. THEN INSTALL Nemesis Service Suite
3. SELECT USB VIRTUAL DRIVE during installation (in case of nokia6120c for nokia 5700 use diamond protection)
4. AFTER INSTALLATION OPEN IT, THEN CLicK ON SCAN BUTTON
5. AFTER THAT CLicK ON PHONE INFO, NOW CLicK ON SCAN
6. NOW CLicK ON PERMANENT MEMORY TAB given on right bottom of application
7. NOW CLicK ON READ, IT WILL READ THE PERMANENT MEMORY FILE & WRITE IT TO THE DISK
UR PM FILE WILL BE LOCATED IN THE PATH:
D:Program FilesNSSBackuppm?252*********.pm
open that PM file in NOTEPAD
8. now scroll uptil FIELD [308] and on the 5th RECORD ur security code is saved
like that
5=31303038350000000000 remove all the "3" digits and it will be like that
5= 10085 0000000000 now its 10085 thats it.UR LOCK CODE IS 10085
are there somebody help me?
my E-mail is: [email protected]
