No display on monitor
SOURCE: Dell Demision 8200 just beep
Kindly follow the troubleshooting steps on the following steps
http://tinyurl.com/dgb5x5
Chances are that you have a loose memory modules
Thanks
Proton
SOURCE: no display and can not boot but gives 6 beeps
1.power supply
2.memory cards
at last mother board need changing !
hope it will help
SOURCE: My dell inspiron 530 beeps
annika2208
In regards to the computer beeps 4 times this usually points to a memory problem. I would try to reset the memory in the system. Also I would try to boot the system with 1 stick if you have more then one stick as it could be just one of the sticks that are bad.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
SOURCE: Dell dimension 4600, won't boot,
hi...you can try to factory reset it if you have an authentic version of windows, by restarting your computer and pressing F8 as it starts, would advise backing up all your files however before doing this
SOURCE: I have a dell dimension
Plug the monitor into another computer to determine if the monitor is damaged or working properly. You can also plug another monitor into your computer to determine the same thing.
When
you plug in the power cord is there any lights whatsoever on the laptop, where
the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,
lights on the computer, hear any beeps or lights constantly blinking, hear the
DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a
second or two? If so the computer is trying to boot or may have booted,
but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the
laptop and why it is not booting. Most times it's a motherboard issue
when you hear beeps or blinking lights continuous. Most times the problem
is with the memory or Video Card. Count the Blinking Lights or Beeps and take
note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge
Buildup. Remove the Power Cord, then Press and Hold the power button for
30 seconds. After 30 seconds plug the power cord back in and hit the
power button to see if it boots.
Maybe
your memory is bad or the memory slot is bad.
Remove
the Power Cord, Open the Case and remove one of the memory chips. Set the
chip aside then try rebooting the computer. If it boots, then you know
the memory chip you set aside is bad so mark an x on it with an ink pen.
If it fails to boot then move the chip to the next memory slot and try
rebooting. If it fails take the chip out and set it aside, then put the
other chip in and try booting it in both slots. If it boots, just to
verify that the chip set aside is bad, mark an x on it and put it into the open
memory chip slot and try booting.
