I have read that the speed sensor near the front flying wheel connected the front roller, sometimes get malfunction. I have just tapped it gently with a screwdriver and this seems to have done the trick. Hope this will help somebody with a similar situation.
Else
Call Vision Fitness Customer Service, they'll help you reset the treadmill by using the console. This will help clear the problem. I've been told that this error occurs when the incline controls are not used often. I've cleared the error using their instructions but after several months it does reoccur. And no I don't use the incline option often so that might explain it
SOURCE: my Lifespan treadmill is showing an E1 error code.
my lifespan treadmill has an error code e1
SOURCE: E1 error code
Your problem might be that the sensor magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
SOURCE: my lifespan treadmill has error code e6, what does this mean?
hello,kindly download the below file... it explains ur error and how to rectify it
http://www.body-solid.co.uk/body-solidUK_download/pdf_docs/tr-20(1)E6+E7(XT-27_33_56_57_7600).PDF
thank you for using FixYa,Thanks,Reymond
When I turn the treadmill on, it turns on normally, but when I press the 'START/STOP button,, the treamill does not start but comes with an Error E06 after 3 seconds..Could you please advise what this error means and what can we do to get rid of this error.
Thanks Sudeep for your advice. I opened the covers near the front rollers, could not locate the sensor. I opened the cover near the motor and the card, clearned the dust etc. Still does not work. Sometime the speed counter starts increasing upto the speed of 1.0 and then shows the E06 error. Though the belt does not move at all even during the counter movement until 1.
I contacted the support, they say the card could be fauly and they can send that for $190. But I am not sure what to do..
My treadmill is saying E06 I need help
