I would like to rebuild or stiffen my M30 Mozo front forks on my Mongoose XR 150 21speed mountain biike
SOURCE: Adjust front suspension on a Mongoose XR-75
i dont think you can......because these bikes are made for confort at a cheap price..........
higher value bikes can be adjusted....they have special shocks and you can adjust on either soft or stiff ride.....
SOURCE: front suspension to soft on mongoose xr-75
The front forks aren't adjustable, as you probably figured out. You can, however, get harder springs if the springs can be accessed at the top of the fork tube. If not, do what I did on my mountain bike. I bought a better pair of adjustable forks that I found on eBay. It will take a bit of investigation on your part regarding the dimensions of the forks, so you get the correct length and width where the forks fit onto the frame (and the overall desired fork length), but you'll be a lot happier with adjustables.
SOURCE: how to adjust the fork suspension on Mongoose Iboc Style# R4654TG
there is an alan key nut usually underneath the "lowers". this takes the lowers off and thats all i know. aslo there is twist things at the top. this adjusts the rebound
SOURCE: loose handlebars on a Mongoose XR-75 mountain bike
Check the splines on the handle bar. Just loosen the "clamp" and slide the bar over to one side enough so you can tell if the are stripped or not. If they are then replace the bar, if not then reassemble and try to put a littlle extra torque on the bolt.
I have noticed with the 2 of these bikes that I have that the bars do not like to stay tight for long, they tend to work thier way loose about every other time we use them. I just keep tightening them untill the splines strip, then pick up a new bar.
Contact Mongoose for parts info at: www.Mongoose.com under "about" click ask mongoose.
Good luck.
SOURCE: I need to find a
Mongoose didn't make the chainring. They're generic (like most bike parts) and have many substitutes. Determine the parameters and then go looking for one that fits.
http://www.sheldonbrown.com/gloss_bo-z.html
Other parts may also be worn, like the chain.
http://www.sheldonbrown.com/chains.html
