When I plug in the pen drive WindowsXP detect the the pen drive and assign a drive letter to it, but when we click on pen drive, it gives message "Please insert a disk into drive...."
Or when we try to format it, it give the message "Insert a disk, and then try again."
Please give me sollution
Sujit Wale
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
First insert your pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
Hello Sir,
If your pen drive is showing this error,you can format your pen drive and even get your data back from transcent orignial formatting software which you can get on there website or here is the direct link
http://www.transcendusa.com/products/online_recovery.asp
same problem here too. Pl some one help !
