Machine was brand new, purchased in December 2011. Oil pan is full. Only gets used 1-2 times a week for 1-2 hours. Broke while stitching jeans. Heavy needle and Heavy thread were being used.
SOURCE: Juki 8300N
Dear Rosemarie,
Make sure you have threaded the machine from right to left, it sounds
like the needle thread is trapped under the lower looper thread and
cannot form a stitch.........start the threading over from scratch like
this:
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any
thread guides on the way, as each one needs to be followed through to
ensure correct tension and thread progression.
Cheerup and Be Happy always
SOURCE: problems when sewing over heavy jean hems
Are you using the correct type of needle? have a word with your needle supplier and explain the problem. Different threads and different thickness material need different top and bottom tension adjustments.
Can I suggest sew one thickness material at a time with tension adjustments for that thickness. Then change the tensions and do a batch of thicker material.
SOURCE: Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
SOURCE: I own a Juki DDL-8300N industrial sewing machine,
Hi, Please accept the solution if it's helpful. Do get back to us for any further query. Thanks for contacting fixya.com
I do understand sometimes the manuals do not give a complete picture. Check out these videos that I have posted bellow. They show how to set it up.
http://vimeo.com/14428186
