Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
Anonymous Posted on Jun 23, 2017
The front display panel does not work after it was clicking and flashing for ages
My side by side american style fridge freezer front display starting flashing and a clicking noise began. This lasted approx 6 months but when I moved house and switched it on again nothing worked. The display panel has a dot on it illuminated. There are no motors running and everything seems dead. I have read other reports on this and I'm starting to think I need to replace the front panel board which is expensive. Could I do this myself ?
5 Related Answers
Anonymous
  • 61 Answers
  • Posted on Oct 06, 2008
SOURCE: Whirlpool front panel dead but cooling
http://www.whirlpool.com/custserv/index.jsp hope this can help
rpbuice
Ron Buice
  • 161 Answers
  • Posted on Dec 21, 2008
SOURCE: Have a whirlpool side by side american fridge freezer,,
If the fan in the freezer is working.
You can hear this fan running when you open the freezer. Then I think the noise you hear is the fan hitting an ice build up.
This is a failure of the defrost system.
Anonymous
  • 242 Answers
  • Posted on Dec 30, 2008
SOURCE: panel between fridge and freezer very hot and no sound at all
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
Anonymous
  • 103 Answers
  • Posted on May 31, 2009
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
Anonymous
  • Posted on Jul 10, 2009
SOURCE: WHIRLPOOL AMERICAN SIDE BY SIDE FRIDGE /FREEZER
I had probably the same problem. After a little discussion with the factory they sent a technician as a "Good Will Gesture." The technician told me it was the control board down by the compressor. I overheard a conversation between he and his central repair office that it was a common problem. The factory would not admit it. I have a feeling the electronic control board he replace (which would have cost several hundred bucks) was probably made in China. Now I'm having more problems with my Ohio made Whirlpool side-by-side. The freezer is working fine, the fridge is not very cold. By the way, the internal lights was one of the keys to the problems.
Water dispenser not working and items in fridge freezing up in Daweo American style fridge freezer
It almost certainly needs a new thermistor, which is the electronic thermostat sensor.
Hi, I have a Lanona HJA6110 American Fridge Freezer. The Freezer works, but the Fridge doesn’t and I get the high temp. Light flashing on the front display panel. Upon opening the Fridge door the fan runs...
Go to Amazon.com or click on this link.
https://www.amazon.com/gp/product/B00W4YG47S/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
Supco SM0146B Refrigerator Evaporator Fan Motor, Replaces Samsung DA31-00146B
The fan motor is essentially a universal fit on several brands of refrigerators. you will have to save the wiring from the original fan and attach some terminals for the replacement fan
Fridge/freezer freezing up
common issue on uk samsung rsh1 american style appliances
easy cured - diy repair kits been on the market a few years now
watch this youtube video for some extra help
1helpful
I am trying to turn the whirlpool space 4 american style fridge freezer on. the fridge seems to be fine, but the freezer side temp display is winking and the temp control is not responding and the warning...
You have a common fault with the electronics.
Check on a large auction site for a repair kit.
Item number: 330363841350
It will only cost £30, better then a few hundred.
Hope this helps
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Samsung american style fridge/freezer
try to reset the unit. Hold inm the top two buttons untill the display blinks and then it should work. Or try turning the uit off for 15 minutes and then back on.
9helpful
Flickering display panel on Whirlpool american style fridge/freezer
Also have the same problem of flickering Whirlpool American Fridge Freezer display, which seemed to start when I changed the filter.
3helpful
2answers
Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
3helpful
4answers
Samsung SRS2028CVW fridge freezer
check out this samsung diy repair channel on youtube ... some great stuff on samsung
samsung fridge freezer problems
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
