Kenmore Elite Oasis 27052 Top Load Washer Logo
Anonymous Posted on Sep 30, 2012
Reset computer or processor
I have heard of a way to reset the computer or processor but I don't remember where I found it. I want to perform it again.
  • 1 more comment
  • Anonymous Oct 05, 2012
    This does not match up with the instructions that i have recieved in the past.
  • ernesto cuadra
    ernesto cuadra Oct 06, 2012
    so read your instr. manual or get support from your supplier manufacturer about this. God bless ou
  • Anonymous Oct 06, 2012
    Logic had taught me that the first and best place to start trouble shooting a problem is with the Owners/Operators manual. When that doesn't work, reach out to those in the field that might have some expertise. That hasn't seemed to work either.
ernesto cuadra
Level 3:
Top Expert:
  • Kenmore Master 12,223 Answers
  • Posted on Oct 01, 2012
ernesto cuadra
Kenmore Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4080956
Points
34431
The reset computer or CPU you must unplugged the washer from the outlet wall by 5 minutes. see the diagram, remember the washing machine is 115vCA NOT 220vca is only example.
God bless you
Motherboard connections (to front panel)
remember the colored wire is +, the + and - should be printed very small on the board near the connectors as well as what they are example (HDLED is hard drive LED) or (PWRLED is power LED) or (PWRSW is power switch) these are examples yours may differ slightly
My computer was replaced after the car would not start. Dealer then found a faulty ground wire. I am wondering if the $1,500 computer needed to be replaced.
We could wonder along with you, because
we would have no way of knowing
There are several things people call computers,
that are just modules or processors & their all over
the car
The PCM/ECM whatever name you prefer, don't fail
often & have no real way to test, as you do with most
components. So,I would say there is a 70% chance
it was good.
Can't remember User Name and Password for Acer Aspire One D270, How do I reset it ?
Typical Solutions:
  1. Try Administrator without a password. Use safe mode if you don't see Admin
  2. Use third party software eg. http://www.top-password.com/reset-windows-password.html
  3. Re-install windows.
Don't remember the admin password & has several things pw protected as well..
I forgot windows 7 laptop password, i just reset windows 7 password by the following steps,
Step1: Download Smartkey Windows Password Recovery Professional from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html.
Step2: Install and launch it to any accessible computer.
Step3: Use a blank and writable CD/DVD/USB to burn Windows 7 password reset disk with the tool.
Step4: Boot the locked computer from CD/DVD/USB.
Step5: Start to remove Windows 7 password with the burned disk.
Step6: Reboot computer and login to the locked PC without password.
Hope it can help you well.
Have no sound and found the audio driver is missing. When performing an update for the driver it can't find it on the net. Need to download manually. Where do I find the driver for this amd athlon 64 x...
Have you tied this link:
http://support.amd.com/us/psearch/Pages/psearch.aspx?type=2.1%3b2.12&product=2.1.2&contentType=Tech+Download+Processor&ostype=&keywords=&items=20
Please let me know if this was helpful and if itsolved the problem and good luck..
Zenith volume issues
If you don't any Volume at all, unplug the TV from the wall for 40Min, and that will reset the audio processor back to normal, if that don't work, then chek for a audio amp IC that could be bad
Looking for a dodge caravan engine computer for sale
Don't think I have ever heard of that, ever
You think or were told to find a pcm & your
looking for a reasonable used one ,that hopefully
you won't have to have it flashed?
They don't fail often & I also have never heard of
one being replaced other than at a repair shop
or dealer.
1helpful
Hi i purchased amd athlon x3 450 and only one core is showed in task manager,performance tab
Hi.
If your system is running XP then there is a file from Microsoft that you can download that may fix the problem. Remember once you have installed the fix you have to restart the computer for any changes to take effect.
Click on the link below for the download.
http://www.microsoft.com/downloads/en/details.aspx?FamilyId=C2AB5A48-8240-4934-BBD8-34FB8A0FCE3B&displaylang=en
If your sysem is not XP and you are using Vista or Win 7 then don't download this fix as it will not work. Instead right click on Computer and select Properties from the sub menu. When the properties window comes up have a look at the processor under System and see if it shows how many cores the processor is currently showing.
Please let me know how you get on.
Good luck.
1helpful
4answers
Runs slow, i do the basic like defrag, clean disk, delet history. internet files, thing of that nature but my hp is slow like my processor is out dated or my processor is trying to hard to complete simple...
Your computer has only 512MB of RAM.That will just barely run your XP,forget about doing anything else.You need a minimum of 1GB,2GB is even better.Your computer works in RAM not your hard-drive.The hard-drive is for storage,the RAM is for running your programs.
http://h10032.www1.hp.com/ctg/Manual/c01311536.pdf
This link is your manual and it will walk you thru the procedure.Hope this helps?
Alexander
vince
