not sure if this will help you at alI, but I found this answer on the following website: .askmehelpdesk.com
and an answer to a similar model here:
http://www.intermatic.com/images/misc/158ej12685ref.pdf Good luck
Plug in timer - The letter C will Flash
TO SET CURRENT TIME:
Press Time Button - It will advance to 1 a.m.
Continue pressing until right time to the nearest hour.
(NOTE: A dot at the bottom right corner of the display indicates P.M. hours).
TO SET ON AND OFF TIMES FOR TIMER OPERATIONS:
Press Mode button - Letter P will flash inviting you to set the program
Press Time button repeatedly until required staring time appears in the window. (starting time is now displayed).
Press Mode button again - the letter E now flashes.
Press time button repeatedly until required ending time appears in the window. (Note: a dot at the bottom right corner of the display indicates P.M.hours).
Press Mode button and the display returns to the current time.
Programming is now complete. You may now plug in whatever needs to be turned on. The device will turn on and off automatically every day at the times you have just selected.
TO REVIEW THE PROGRAM
Press time button - Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
TO CHANGE YOUR PROGRAM
Unplug the timer, which will discontinue the current program. After 10 seconds, plug it in again and proceed to set current time. Then continue with the programming steps as above.
FOR MANUAL OVERRIDE
Pressing the Mode button at any time will turn on the devices plugged into the timer. The display will indicate the letter O. The devices will remain on until the ending time of the daily program. To return the timer to the automatic mode prior to that hour, press the Mode button again. The display will return to show the current time.
AFTER A POWER INTERRUPTION/FAILURE
The timer will return to displaying a flashing C and the devices plugged into it will be off
